Rear rim rubbing on shock
Old 09-23-2018, 05:32 PM
Badgrlz
Badgrlz's Avatar
Default Rear rim rubbing on shock
350z 06...was hit on right rear low impact right quarter panel and rim. Got it out of body shop..there as no r
Frame damage but since april of this year when it was hit... I can not get my rim to not rub on shock... put adjustable camber arms on both sides and toe bolts. I am so annoyed.
Old 09-23-2018, 09:52 PM
Received 2,296 Likes on 1,653 Posts
Is the wheel bent
Old 09-24-2018, 11:57 AM
Cracka350
Cracka350's Avatar
Double check your hub to make sure it's ok. You can check by jacking it off the ground and firmly trying to shake the wheel from side to side. If there's any play, replace it. You may also want to have your alignment checked. Maybe the camber is off.
AllstarE4
Texas Marketplace
09-17-2018 06:09 AM
bcoffin23
08-23-2018 09:37 AM
BurntCopy
08-02-2018 11:13 AM
Quick Reply: Rear rim rubbing on shock
