Won't rev more than 3000 while drifting
Old 10-20-2018, 10:01 AM
Walid
Walid's Avatar
Default Won't rev more than 3000 while drifting
Hi All
I have a 2005 American spec 350z with no VDC. I am preparing it as a drifting car but this problem has stumped my mechanics. In second gear while drifting or doing a donut, the car has a loss of power as though something is stopping it from reving above 3000. The car revs fine in a straight line and seems like it has all it's power.
Here is the setup that's relevant
New walbro fuel pump and new fuel filter
Welded differential
K&N air filter (tried with and without it)
Abs clip near brake cylinder unclipped (tried with and without)
tried unhooking and rehooking the battery
Mechanic also removed some sensor or wire where the pedals are .. still the same..
I've read a lot online but haven't found anything definitive so I appreciate any help!
Old 10-20-2018, 03:57 PM
Received 2,296 Likes on 1,653 Posts
Only 2nd gear ?
Old 10-20-2018, 08:31 PM
Walid
Walid's Avatar
In 1st too but haven't tried 3rd because haven't reached high enough speeds .. thanks
Old 10-20-2018, 09:22 PM
Does the car have TCS? Aftermarket taillights?
Old 10-20-2018, 09:31 PM
Walid
Walid's Avatar
The car doesnt have TCS (Im assuming because there is no TCS button, please correct me if Im wrong and if so how to disable it)
YES for aftermarket tail lights ... but this happens when the lights are off, although yes, before the "donut" or drifting session I would have pressed breaks before accelerating, but not during.
Old 10-21-2018, 04:35 AM
BluestreamDE
BluestreamDE's Avatar
https://my350z.com/forum/exterior-an...using-ecu.html
Old 10-21-2018, 06:29 AM
liven Z life
liven Z life's Avatar
Does it like buck when it hits that’s mark? Limp
mode?
Old 10-21-2018, 09:07 PM
Walid
Walid's Avatar
mode?
It doesnt "redline" at 3, it just peaks at 3 to 4k RPM when drifting and then feels as though it cuts the power which gradually starts coming down even though my foot is to the floor on the accelerator. before and after this, on a straight line, it drives normally.
JasonZ-YA
Drift
179
12-15-2020 10:05 PM
brotherhef
11-09-2008 08:56 AM
Quick Reply: Won't rev more than 3000 while drifting
