My 350 z is acting like tranny is sliping
Old 11-13-2018, 05:01 PM
Delvin
Delvin's Avatar
Default My 350 z is acting like tranny is sliping
Is there a problem using different tires size on rear of my 350z than what specs are
Old 11-13-2018, 05:05 PM
Delvin
Delvin's Avatar
some mechanic said that's making my car say sliping on the dash and it not going in gear please any help with this is very welcomed
Old 11-13-2018, 06:10 PM
Received 3,263 Likes on 2,321 Posts
Short answer: Yes and no.
The yes part: What's your trim level? Sounds like you're having VDC or TCS issues due to a tire too short in the back. What size?
And "no" because none of those issues should keep your trans from engaging.
Old 11-13-2018, 07:00 PM
Delvin
Delvin's Avatar
Default 245 45 zr 17 94w
235 45 zr 17
Old 11-13-2018, 07:01 PM
Delvin
Delvin's Avatar
Default 235 not 245
235 not 245
Old 11-13-2018, 07:48 PM
Delvin
Delvin's Avatar
Default 235 not 245
235 not 245
Old 11-13-2018, 09:00 PM
jhc
General & Tech Moderator
jhc's Avatar
235 45 zr 17
235 not 245
235 not 245
You OK br0? Wake-and -Bake often?
Old 11-13-2018, 09:47 PM
Heh heh....
But back to the original question.... yes, 235/45 is almost an inch shorter 0.93") than the stock 235/50-17. Since diameter is smaller, the wheelspeed is higher given any speed the vehicle is traveling. This looks - to the ECM - like the tire is spinning and initiates VDC or TCS to compensate, throwing the SLIP light. Get the right size (height) tire on there and the problem goes away.
Old 11-13-2018, 10:00 PM
Received 2,296 Likes on 1,653 Posts
Front and rear tire sizes please
kensin0429
11-02-2006 12:57 PM
Fairlady_z33
02-09-2006 05:30 AM
BigEquity
Videos
15
09-29-2004 07:31 PM
Quick Reply: My 350 z is acting like tranny is sliping
