Between the 2, which exhaust should i get?
Old 03-23-2019, 01:42 PM
LordBootz
LordBootz's Avatar
Default Between the 2, which exhaust should i get?
Motordyne or Ark Performance which sounds better in your opinion? How do you get the popping noise in your exhaust? I have a automatic Z
Old 03-23-2019, 02:46 PM
Better.....but still wrong section
Old 03-23-2019, 03:17 PM
Popping noise.... wow, that's two in two days.... Is there something going around on the 350Z FB groups about this bit of nonsense? Psh, like the guy who came here asking all about spacers and got a bunch of great advice then never shows up here to thank anyone but shows off the car on Facebook. Ehhhhh.... the signal-to-noise ratio continues into the basement...
Not to mention I hit "New Posts" and more than half the threads (8 of the 17 or so) are from PWRR.... oy. Think my time has come....
Old 03-23-2019, 03:20 PM
mr. sparco
mr. sparco's Avatar
You will need a couple of big fat snails bolted onto the motor or just mess and screw up the AFR on your NA tune, pop away!
Old 03-23-2019, 06:40 PM
No_name
No_name's Avatar
Hang in there man...
Old 03-23-2019, 09:43 PM
bad boyz
bad boyz's Avatar
Sit them down at the kiddies table and tell them to stay there until they grow up!
Old 03-23-2019, 11:23 PM
zwei_the_c
zwei_the_c's Avatar
First Question: Motordyne
Second Question: back-pressure & tune
LordBootz (03-24-2019)
Old 03-24-2019, 05:40 AM
jellofuel
jellofuel's Avatar
I like both exhaust systems, so no recommendation there. On Facebook, I'm seeing more n/a builds with flame maps, it basically dumps fuel when you lift off the throttle, shooting fire out the exhaust. The popping usually occurs when you get test pipes (decats). It's the combination of test pipes and flame maps that's making the rounds on FB right now. Hope that helps!
Old 03-24-2019, 06:16 AM
dboyzalter
6 inch cawk is my fave!
dboyzalter's Avatar
Damn I was going to take my car out for a drive later because its nice outside today. But now now I gotta figure out how to make popping noises...
I bet if I drill holes in my catalytic converters that will be a good start.
For the flames im going to go ahead and rig up a drip from the gas tank and get a grill igniter mounted in my tail pipe.
The following 2 users liked this post by dboyzalter:
blufc3s (03-25-2019), SPM350Z (03-24-2019)
Old 03-24-2019, 06:28 AM
Chihuahuamaster
Chihuahuamaster's Avatar
Popping noise, automatic z, = fail... However I would recommend any local exhaust shop, and ask them to 'straight pipe' your car. Seems more up your alley.
Old 03-24-2019, 06:36 AM
Chihuahuamaster (03-24-2019)
LordBootz
03-23-2019 01:34 PM
Asian Invasian
09-08-2009 03:18 PM
cyberkline
01-31-2008 06:30 AM
Stillen350z
12-16-2002 05:55 AM
Quick Reply: Between the 2, which exhaust should i get?
