tire guru please help - 2013 new tires or 2015 used?
Old 03-25-2019, 09:19 AM
32rulz
32rulz's Avatar
Default tire guru please help - 2013 new tires or 2015 used?
i came across a set of brand new never use cup2 made in 2013 vs a set made in 2015 50% thread,
which ones would you choose and why?
TIA
Old 03-25-2019, 10:30 AM
TIA
Depends on how you plan to use them. If track, neither. Do you want to trust your car on 6 year old or half trashed tires with unknown heat cycles? Probably not a horrible thing but why take chances?
Point A to point B, Cup 2s on an occasional (dry weather) driver. But then again, if you're only streeting them, Cup 2s are a waste and could ultmately be hazardous in the wet and cold temps.
32rulz (03-25-2019)
Old 03-25-2019, 11:39 AM
dkmura
dkmura's Avatar
Mic has covered the basics on this. If these old/used tires are that cheap, than MAYBE they're a good stop gap. Otherwise, with the expected rubber compound degradation and outright wear, the money might be better spent on a new set of tires. BC is known for wet weather, and I'd look for a set of high-performance tires more suitable for those conditions if your Z is primarily a street car.
32rulz (03-25-2019)
AlexAZD
South West
09-03-2015 08:21 PM
jubes
02-18-2009 02:19 PM
twotonetrack
11-06-2006 02:41 PM
bhk1004
02-08-2005 03:58 AM
Quick Reply: tire guru please help - 2013 new tires or 2015 used?
