bcm question (nats)
bcm question (nats)
so i just send my ecu to uprev and order the nats disable. i have been emailing the support team and i have a question unanswer because they do not know if it need to be reprogram
since i brought a new ignition switch (came with the key and the black box) and i was wondering if i will still need to have the igniton and the key reprogram still or can i use turn and start? the dude from support team said i dont know maybe. also i know alot of peoples it will disable or you got to disable nats, do they mean disable nats forever or just until the problem happen again? im having second thought like i dont want to plug everything back up and call a locksmith and something happen and the immoblizer to turn on again and also should i buy the bcm from the 350z where i got the igntion switch and the key from to be safe or i shouldnt have anything problem after pluging everything back up and calling a locksmith to reprogram.
solidfish
06-08-2010 08:49 AM
