Need help with fitment!!
Hey so I was looking at these wheels on fb marketplace and I was wondering if they would fit my 2003 Nissan 350z enthusiast it’s currently on stock suspension without any issues (btw I’ve never had to buy aftermarket wheels so any help would be greatly appreciated!)
These are your friends
https://www.1010tires.com/Tools/Whee...et-Calculator#
https://tiresize.com/calculator/
Offsets too aggressive without work to make them fit. (Roll and sealing of fender guards, height and camber adjustment if lowering.) And using negative camber to fit rollers is just, well, not a good idea.
Tires are too short. They'll work but 35 aspect tires on 18s are >1" shorter than stock height and will leave big fender gap on stock suspension.
As pointed out above, go with at least +15mm (or higher) offset front or better, +20ish all around (even with staggered width). is ideal.
It should also be noted that the offsets being recommended are based on the width of these wheels.
For example: an 18x8.5 +3 will fit the same as a 18x9.5 +15 in relation to the fender.
The wheels are a common setup on the more aggressive side. The tire selection sucks
