FS Local Only Central FL 2 kenwood 10" subwoofers and amp w/ box
Old Mar 26, 2009 | 06:17 PM
Pinoy31AP's Avatar
Pinoy31AP
Default FS Local Only Central FL 2 kenwood 10" subwoofers and amp w/ box
I have 2 kenwood 10" subwoofers with a kenwood amp. this comes with a zenclosures box. system sounds great. its still in the car so you can hear it before you buy it. looking to get 300 for everything. all you would need is the amp wires.
KFC-W2511 10" 1000W Subwoofers
* 10" SVC 4-Ohm Subwoofer
* Stainless Steel-Coated Polypropylene Cone with Rubber Surround
* Super Linear Spider
* Double Stacked Magnet
* Extended Pole Piece
* Plastic Decretive Ring x 2
* Reverse Mounting Option
# KAC-7204 2-Channel 1000W Amplifier
* Stereo/Bridgeable Power Amplifier
* 2-Ohm Load Capability
* Front-Mounted Controls
* Line Output Terminals for Extension
* Speaker Level Input
* 1000 Watts Maximum Power
* 500 Watts RMS Power
* Gold Plated Power and Speaker Terminal
* Cast Aluminum Heat Sink
* Single-Side Exposure of Terminals for Multi-Installation
* Power MOSFET Switching Power Supply
* Signal Sensing Turn-On
* Cooling Fan
* Blue Illumination
* Built-in Variable Low-pass Filter and Infrasonic Filter
# SPECIFICATIONS
* Amplifier Class : Class A/B
* Number of Channels : 2-Channel
* Maximum Power : 1800 Watts
* RMS Power Output @ 4 Ohms : 120 Watts x 2-Channel
* RMS Power Output @ 2 Ohms : 250 Watts x 2 Channel
* Bridged Power : 500 Watts x 1-Channel
* THD : 1%
* Signal-to-Noise Ratio (dB) : 100dB
* Frequency Response (Hz) : 20Hz~20kHz
* Built-in Crossover : Yes
* High-Pass Crossover Frequency : 50Hz~200Hz
* Low-Pass Crossover Frequency : 50Hz~200Hz
* Bass Boost : 0dB~18dB
* Bass Remote : N/A
* Fan Cooled : Yes
* Fuse Rating : 40A x 1
* Dimensions (Width x Height x Depth) Inches : 13-3/4" x 2-5/16" x 9-3/8"
* Approximate Weight : 8.4 LBS
BEBO'S ZEE
Jun 7, 2016 07:48 AM
KJ-350
Apr 11, 2003 10:34 PM
lbccpt
Dec 31, 2002 02:33 PM
