possibly moving to phoenix.. curious about smog
Hey guys, i might be moving to arizona soon and moving into the phoenix area. What type of smog rules are they? how do they test smog? has anyone dealt with smog on a greddy tt car? how often do you need to smog? Thanks...
i know they cant be tougher hence why i am moving out of california.
however i would like to know what the exact specifications are used during smog tests.
i do have an 05 and when i move they dont have to smog YET but i would like to know for the future.. Thanks
Sorry, I dont know the answer but Im trying to look out for a fellow board member so I must say this. WHY THE **** ARE YOU MOVING TO AZ from CA???? I hope your getting a ton of money for it. The day I moved to ca from AZ was the best day of my life.
Ok. Good luck.
Ok. Good luck.
in arizona in areas that are considered non atteinment areas such as phoenix and tucson (metro areas) cars need to meet emmissions standards,cars that are 5 years old all the way down to 1967 must be tested;current year 2008,all cars 2003 and older;your car will not need to be tested untill 2010 (2005+5) ,and even when newer cars are tested,they only do a test of the cars systems ,they plug in to your car and scan for codes,check engine light on dont even show up get it turned off then it will pass(should) ;i think 1998 and older get the acctual pipe test done
...and just wanted to mention that your post was supremely unhelpful and stupid.
Hi Schism-
My question might pertain more to Nevada reg and protocol unless they are the same as AZ smog regulations and protocol.
My car is turbo'd now but in a few years, I wish to do a build and I am weighing different options.
I was under the impression that states not as strict as Cali just did tail pipe sniffer tests but it appears that youo guys all have to do OBDII hook-ups?
I'm concerned becaue I am throwing codes as I am thinking about having a friend in NV help me by registering the car out of state.
Are you modded?
Are you modded?
When I smogged had my 03 coming from KS to AZ, all they did was hook up to the computer or OBDII I think, then did a gas cap ck too and I was good to go. No sniffer test either.
I wasn't modded though. I think as long as you're not throwing codes they will pass you.
Tochigi_236
Sep 27, 2015 03:40 PM
