Crate motor coming soon!
SGP Racing VQ35 engine
Block oil passages cleaned
Block redecked
Block Bored and Honed using a Torque Plate
Crank balanced
Crank journals polished
New Main and Rod bearings w/ceramic coating
Pauter Rods
ARP Rod Bolts
CP Pistons .020 over(8.5:1 or 11.5:1)
*Ceramic coating on Pistons
ARP Main Studs
ARP Head Studs
Heads oil passages cleaned
Heads redecked
Ported exhaust and intake runners
*JWT Upgraded Cams
*JWT HD Valve Springs
5 angle valve job
Valve Stem Heights set
Cold Clearance set
New Valve stem seals
New Nissan Head gaskets
New Nissan Oil Pump
New Nissan Cam seals
Currently running the PE kit on the stock motor putting out about 7psi thanks to HKS vpro, Blitz boost controller, and of course XS engineering for the tune.The car recently dynoed at Stillen day and made 347 hp and 329 ft/lbs of torque with boost around 6 psi.This an automatic 350z w/touring trim and is in the current sport z magazine under the boost it article.With this new SGP racing set up and the install/tuning by XS engineering we are looking for 18 lbs of boost and 550 hp+! Yes we plan on doing tranny work as well.XS engineering is saying more like 615 hp.We will see soon the motor should be shipped out this month.
Block redecked
Crank balanced
Pauter Rods
ARP Rod Bolts
ARP Main Studs
ARP Head Studs
Heads redecked
*JWT Upgraded Cams
5 angle valve job
Cold Clearance set
New Nissan Oil Pump
