Good shop to install a Crank pulley in 626?
Old May 25, 2007 | 10:05 AM
Pooplet's Avatar
Pooplet
Default Good shop to install a Crank pulley in 626?
I need a GOOD shop that can install a unorthodox crank pulley without screwing up the install . I dont really want to use a dealer due to high labor prices and Im not so sure about using a import shop. Thanks alot!
Old May 25, 2007 | 10:36 AM
groovin_350z's Avatar
groovin_350z
Sleeps in 350Z
IMPEX in san gabriel. they do all my installs . they're really good.
give them a call
ask for Harry and tell him quan sent u.
626.285.6630
Old May 25, 2007 | 12:08 PM
ML37's Avatar
ML37
*AutoHan*
18507 Valley Blvd
La Puente, CA 91744
www.autohanperformance.com
626 581 2001
ask for HAN. tell him marcelo sent you.
Old May 25, 2007 | 12:13 PM
AFKGuy's Avatar
AFKGuy
Originally Posted by ML37
*AutoHan*
18507 Valley Blvd
La Puente, CA 91744
626 581 2001
+1 Han FTW!
BTW, I tried calling you guys yesterday and it seems like that number is out of service?
Old May 25, 2007 | 12:17 PM
hwcustoms's Avatar
hwcustoms
https://my350z.com/forum/showthread....ghlight=pulley
Check out this link if you are in the DIY mood. It is very easy to do if you do not want to fork out a bunch of cash.
Old May 25, 2007 | 12:56 PM
spyderZ's Avatar
spyderZ
Diy Ftmfw!
Old May 25, 2007 | 01:32 PM
THE TECH's Avatar
THE TECH
I'm not a fan of aftermarket crank pulleys. In the long run, you're just asking for trouble IMO, especially if they aren't balanced.
Old May 25, 2007 | 01:45 PM
___DJK___'s Avatar
___DJK___
Are there any documented cases of failures with UR pulleys? I haven't seen anything negative...
I know there are documented cases showing the CNR pulleys causing oil leaks but I haven't heard anything bad about UR.
Aside from any potential issues its a nice mod, the car revs faster and has better throttle response.
(I haven't had any issues with my UR pulley )
Old May 25, 2007 | 02:02 PM
THE TECH's Avatar
THE TECH
Documented, I have no idea. I do know that aftermarket crank pulleys can cause severe damage if they are not balanced properly. This is why with Supras in particular, we do not install unbalanced pulleys. They are not worth the minimal gains that you might get with them. The oil leak that you mentioned is actually an insight to a larger problem...the front main seal.
Old May 25, 2007 | 03:42 PM
wynd d z33's Avatar
wynd d z33
performance nissan has a 50% off installations promo in the month of may i believe so get them to do it for you and i bet they'll do a great job on it contact andy he'll help you out... i haven't heard any problems in UR's i may get one
Old May 25, 2007 | 04:01 PM
ML37's Avatar
ML37
Originally Posted by AFKGuy
+1 Han FTW!
yeah somethings wrong with the line bc of the credit card machine. if you need to get a hold of him, pm me and ill give his private line
Old May 25, 2007 | 04:19 PM
kylekyle350z's Avatar
kylekyle350z
give them a call
626.285.6630
+1!!
they get the job done
Dr.Paulyy
Jul 29, 2019 07:45 AM
NissanZcrazy
Sep 23, 2015 07:59 AM
EnjukuRacing
Sep 11, 2015 08:34 AM
EnjukuRacing
Sep 11, 2015 08:30 AM
