help!! need fenders to be rolled
Old Aug 19, 2007 | 09:57 AM
wynd d z33's Avatar
wynd d z33
Default help!! need fenders to be rolled
i was looking around searching for about a day or two found someone that interests me to do the job but is unavailable to do it soon dont want to wait till next weekend because my tires are rubbing pretty good wanted to do this asap so if anyone has any input with a good shop or with someone else that had a good experience let me know if not ill just have to wait. thanks
Old Aug 19, 2007 | 10:14 AM
gimpster621's Avatar
gimpster621
go to status. rick had me in and out in like 30 minutes
Old Aug 19, 2007 | 11:45 AM
wynd d z33's Avatar
wynd d z33
ya i think he's closed on sundays but ill give him a call thanks anyways
Old Aug 20, 2007 | 07:36 AM
THE TECH's Avatar
THE TECH
Your tires aren't gonna go bad in a couple of weeks if you have to wait.
Old Aug 20, 2007 | 09:19 AM
wynd d z33's Avatar
wynd d z33
well im not sure cause im seeing were the tire is rubbing from the middle were it says toyo up and on the end edge were the tires starts its leaving a rub line
ever heard of wheel supply they say they roll fenders?
Old Aug 20, 2007 | 09:23 AM
THE TECH's Avatar
THE TECH
What type of setup are you running?
Old Aug 20, 2007 | 09:26 AM
deviljon's Avatar
deviljon
wheel supply rolls fenders, but they may charge a lot.
Old Aug 20, 2007 | 09:27 AM
wynd d z33's Avatar
wynd d z33
dam it!! hows there work any good?
Old Aug 20, 2007 | 09:34 AM
gimpster621
rick charged me 70 bucks for a fender shave. well worth it give him a call if you need it asap =D
Old Aug 20, 2007 | 09:41 AM
wynd d z33's Avatar
wynd d z33
well i took them to status a while back but they didnt cut much i believe i just put on some 285/35/19 and my offset is 18 dont like hearing the rub for any little dip i have my suspension rate max running stiff all around lol
Old Aug 20, 2007 | 09:57 AM
wynd d z33's Avatar
wynd d z33
just called wheel supply 40bucks a fender not bad saves me from going out to redondo during traffic and all but he said that they need to be cut and since they cut them already he needs to check out the fender
Obadabot
Jun 18, 2023 11:31 PM
Justin100
Nov 25, 2021 06:26 AM
