Problem with the z
Old Dec 5, 2007 | 03:03 PM
TBDesigns's Avatar
TBDesigns
Default Problem with the z
Well for some reason when I start the car it idles down to almost 0 like it's going to die and doesn't them goes up to 1000RPMs. Lastnight we started installing my amp and sub box but nothing is connected to the battery. Anyone have a clue its never happend before any other time just started lastnight and does it everytime I start up.
But if I'm on the freeway and come to a stop it's fine. It doesn't try to die
Old Dec 5, 2007 | 03:24 PM
HR Autoparts's Avatar
HR Autoparts
HR Autoparts
hows the rpms at idle? might possibly be a vacuum leak
Old Dec 5, 2007 | 03:29 PM
TBDesigns's Avatar
TBDesigns
Well after the start and its goes it's just below 1000 rpms. It's weird cause the lights don't dim or anything. Just wants to idle low like it's going to die.
Old Dec 5, 2007 | 03:34 PM
Jarred@Z1's Avatar
Jarred@Z1
Z1 Motorsports
did you un hook the battery? if so you have to relearn the throttle body
Old Dec 5, 2007 | 03:49 PM
TBDesigns's Avatar
TBDesigns
Yes I un hooked the neg on the battery and I unscrewed the top screw on the positive but didn't pull it off all the way just the top nut.
Relearn the throttle body? any help on how?
Old Dec 5, 2007 | 05:10 PM
THE TECH's Avatar
THE TECH
You sure about that??
The only time you have to deal with the TB is if you disconnect it and don't reconnect it before turning the key to the car.
Old Dec 5, 2007 | 05:11 PM
THE TECH's Avatar
THE TECH
Be more specific as to what you've done to the car since this has started happening.
Old Dec 5, 2007 | 05:24 PM
TBDesigns's Avatar
TBDesigns
I hvent did anything to the engine or anything. I installed a amp 2 10s and compaitor.
I have a question under the passenger side of the car under the side skirt there is a bump that runs from front to back what inside there? cause my brother drove my car and couldn't get it out the driveway and went off the crub and it dented that thing pretty bad. any gas line or anything run through there? its just fluttering I'm driving right now. never seen this car run like this.
Old Dec 5, 2007 | 05:41 PM
THE TECH's Avatar
THE TECH
Well you may want to take a look under your car if you know something bad has happened to it. At this point, it could be anything.
Old Dec 5, 2007 | 05:42 PM
c3 rolling's Avatar
c3 rolling
umm....bad alternator?
Old Dec 5, 2007 | 06:01 PM
THE TECH's Avatar
THE TECH
Probably not since once it drained the battery, the car would just not start at all.
Old Dec 6, 2007 | 07:31 AM
TBDesigns's Avatar
TBDesigns
Going to take it to westco this weekend hopefully
Old Dec 6, 2007 | 11:04 AM
Mike@JTuned's Avatar
Mike@JTuned
Why does everyone keep suggesting battery? What does idle have to do with a battery? Don't Z's have a voltage indicator?
TPS? IAT Sensor? Dirty filter? MAF Sensor? Those might be more likely culprits.
Old Dec 6, 2007 | 11:45 AM
LaPuLaPu's Avatar
LaPuLaPu
here's a similar situation. you might want to try the individual's solution which Jarred mentioned.
https://my350z.com/forum/showthread....arm+start+idle
Old Dec 6, 2007 | 03:04 PM
dubtunited's Avatar
dubtunited
i know the next questions gonna be "how do i reset the ECU and the throttle valve position learning (accelerator pedal method)?"
so here you go:
http://www.technosquareinc.com/350reset.htm
Old Dec 6, 2007 | 08:14 PM
monokuroboo's Avatar
monokuroboo
CHRIS (350) FTL
???? being specific/pointing out where might also be a good idea. here's a pic for reference:
fullsize pic here: http://img233.imageshack.us/img233/7...ttomei6zu0.jpg
Old Dec 7, 2007 | 07:36 AM
dvo's Avatar
dvo
I had the sme problem when I swapped out plenums. Forgt to install one of the vacuum hoses. Put it back on and everything was A-OK
Old Dec 7, 2007 | 07:42 AM
TBDesigns's Avatar
TBDesigns
This is the area that got smashed up when it got caught on the curb. Ill try to take pictures once it stops raining. It's like a grey over with something rough sprayed on it. it just smashed in. The problem has stopped though for some reason.
Old Dec 7, 2007 | 07:43 AM
THE TECH's Avatar
THE TECH
Loose wire?
BTW, no worries about damaging anything on that spot on the car other than cosmetic.
Old Dec 7, 2007 | 07:48 AM
TBDesigns's Avatar
TBDesigns
Originally Posted by THE TECH
Loose wire?
Thats what I thought just looked like a plastic piece. Just wanted to make sure no gas line or electric lines ran under it and got smashed.
Uriyo_
Sep 8, 2021 08:46 AM
TDPrank
Sep 28, 2015 06:29 AM
