TINT HELP (ASAP)
Old Nov 2, 2008 | 10:02 PM
IbarraZ33's Avatar
IbarraZ33
Default TINT HELP (ASAP)
i need a tint shop that can remove tints ASAP. please help me out guys. im in the burbank/glendale area and need one for tomorrow !! fix-it-ticket FTL . :\
Old Nov 2, 2008 | 10:12 PM
calin's Avatar
calin
I thought any tint shop can remove tint. If they can put it on, why can't they take it off?
Old Nov 2, 2008 | 10:54 PM
Nastyboy's Avatar
Nastyboy
Just do it yourself!
Go to a hardware store / auto supply and purchase a couple of razor blades and take your time removing the tint. No special tools no special skills. Just time.
Off topic: why do people always avoid getting their hands dirty on the most simple tasks? I'm surprised no one is asking help in checking their tire pressure or oil fluid levels...
Old Nov 2, 2008 | 10:58 PM
calin's Avatar
calin
+1
I don't think removing tint should be too hard. Just be careful not to scratch your windows with the razor blade. Besides that, you should be fine
Old Nov 3, 2008 | 12:31 AM
bluezup's Avatar
bluezup
first try cutting it from the edges. when you get some off pull slowly with your hands. pull as much as you can off slowly. what ever you can get off, spray water or glass cleaner on it, and hold a razor blade at an angle and push down. your not actually gonna be slicing with the blade. more like digging into the tint.
just keep the blade at an angle and wet it, make sure the razors are new, other then that dont worry its not that easy to get scratched if done right
Old Nov 3, 2008 | 07:36 AM
DVFlyer's Avatar
DVFlyer
Speed of White
Would using a heat gun help?
Old Nov 3, 2008 | 07:51 AM
m0nkie's Avatar
m0nkie
^I think tints stick on more and dry up faster with heat gun... you are suppose to keep it wet, not dry.. use soap water!
Old Nov 3, 2008 | 09:13 AM
Ricfutures's Avatar
Ricfutures
Fix it tickets are usually for the passenger and driver side windows which are very easy to remove. I do not think they can ticket you for the rear hatch glass which is a nightmare to remove.
Passenger side windows are very easy and shouldn't take more than 15 min each.
Old Nov 3, 2008 | 10:22 AM
Nastyboy's Avatar
Nastyboy
Actually, if you use rubbing acohol (sp?) it will work better/faster/cleaner. The alcohol will help with the adhesive residue.
Old Nov 3, 2008 | 05:45 PM
aldrich's Avatar
aldrich
Default tint
its so easy to take it off go to pepboys ang get the kit. i did it by my self... i can do it 4 u...
Old Nov 5, 2008 | 10:47 AM
xkevon's Avatar
xkevon
did you have any glue residue left over?
is it hard to take off?
my fix it ticket is due on the 17th and i need to take mine off
Old Nov 5, 2008 | 09:14 PM
m0nkie's Avatar
m0nkie
^ use googone
Old Nov 5, 2008 | 09:31 PM
4thHorse's Avatar
4thHorse
This is what I did.
Bought a portible cloths steamer.($25 at Target)
Steamed off the driver side in 30mins because I was on the phone
steamed off the passenger side in 10mins
Returned the steamer the next day
This is the best way to do it your self, it gets all of the glue and everything. It all came off in one peace.
Old Nov 5, 2008 | 11:20 PM
A.H's Avatar
A.H
IF you don't want to do it yourself go to Distinctive Automotive in Woodland HIlls. Should be close to your area too. I know the owners and they are a top notch shop. They have about 40 famous peopel that have brought their cars their with their pictures and autographs and they do a lot more than jsut tinting.
Old Nov 6, 2008 | 06:33 AM
m0nkie's Avatar
m0nkie
Man this thread is still going... I figured if you have soap water and a blade you'll take care of this already...
if anything, go to a shop and say, Heytake it off for free or cheap and I'll be back in 1 hour to put it back on
Old Nov 11, 2008 | 09:35 PM
xkevon's Avatar
xkevon
damn i should have listen to you guys. so anyways i got my tint off this morning at a exotic tint in montrose for 15 bucks for the front windows. basically all you need is a razor to peel the tint off which all came off in like a sec in one piece. the guy just scraped the edge and peeled the tint right off. and for the glue residue, he only used soap and water and just scraped it off with a razor and thats it. he also only charges 40 bucks to retint both windows which is a damn good price. the other tint place where I got my old tint gave me a price $20 each window to take of the tint and $50 each window to retint
etkms
Jun 19, 2022 06:30 PM
LunchBox20
Oct 20, 2015 10:22 PM
