avoid percision audio sounds chino hills if at all possible
Old May 26, 2009 | 12:23 AM
350Z_GTS's Avatar
350Z_GTS
Angry avoid percision audio sounds chino hills if at all possible
like the title says, aviod this place if you car about your car at all. I dont care if anyone is associated with them on here. If you car is still running good then my hats off to you. To start, i had an alarm installed about a month ago. The owner told me he was doing the install and that the install is only as good as the installer (good hook). To make this short, the alarm itslef was in the most obvious spot ever. the wires werent even run nicely through the engine bay (the black wire cover only made it look nice). So i relocated it to a better spot that took me an extra 30 min. (good luck finding it where it is now) Then the shop told me i had 1 touch up and down windows......that only worked on my stock remote. Yea, no @#$%. Ended up taking it to a place that had experience, steves professional tint and audio in montclaire i think the location is. Great service, pricey but excelent service. The guys knew exactly what to do when i told them the windows down didnt work. Apperently the instruction manual didn't tell percision how to do that. And what put me to the point of writting all of this was this, i finally figured out why my car smelt like wet dew in the morning. I washed it and got in the car for the first time with no shoes and the floor board was soaked. The shop didnt feel like putting a hole in the rubber seal where all the electrical was in the firewall so they decided to just pull it out and run the wire up out of it, leaving a huge gap and obviously not sealing the car from water. I on the other hand put a hole in the rubber seal after remounting it and covered the hole and wire on the outside with silcon to prevent water from getting into the extremely small hole i made. So thanks for the horrible install, and no, there is no way in hell i would ever go back if i had a problem. If instructions on how to install alarms are ever are made easily accessible i would worry. Thanks 350Z for the vent spot. I feel slightly better now that others might not end up like me.
Old May 26, 2009 | 12:38 AM
SoCalcruiser's Avatar
SoCalcruiser
sucks to hear. the place i go for car alarm is Best Tint, a bit north on beach from autobacs. lol also the place i go for tint
Old May 26, 2009 | 04:49 AM
SoarVigor's Avatar
SoarVigor
Sorry to hear
Obadabot
Jun 18, 2023 11:31 PM
samansharif
Sep 25, 2015 12:31 PM
