Eclipse AVN2454 - double din touchscreen Navigation DVD MP3 system
Old Jul 30, 2009 | 11:48 AM
shensuji's Avatar
shensuji
Default Eclipse AVN2454 - double din touchscreen Navigation DVD MP3 system
SOLD***
  • Ecvlipse AVN2454 Navigation unit
  • Original owners manual
  • Original Installation insturctions
  • Original wiring and hardware
  • Original remote control
Navigation disc loading.
Touchscreen functionality
Various map views
Navigation route options
Dual slots: One for CDs/Mp3s while the other is for DVD Navigation/DVD video. For obvious reasons, navigation screen will not be operable when DVD video is in play.
Monitor tilt function: just in case there is sun glare from driving at certain times.
Various degrees of monitor tilt.
JDM Insider - DVD not included :tongue:
DVD functions
The Eclipse AVN2454 is an “all-in-one” audio/video/navigation system. It has a CD player as well as a DVD video/navigation player built in to a double DIN space. It does not have any additional boxes. (Installers rejoice!) The front of the AVN2454 features a stylish 6.5-inch TFT touch screen display that’s tiltable to optimize viewing conditions. Press the open button, and the face can slide completely down exposing a slot for the CD player and a slot for the DVD/Navigation.
Its speaker outputs are rated to deliver a maximum of 50 watts per channel x 4 with front, rear, and non-fading RCA outputs capable of 0.8 Volts RMS. The AVN2454 will also control a changer, accommodate a rear view camera (a proprietary piece from Eclipse), and accept an aux AV input. This control unit will play CD, CD-ROM, CD-RW, MP3, DVD Video, and DVD-R Video. Think of the AVN2454 as your audio/video/navigation nexus. It pretty much does it all.
Souce: CarSound.com for more details
Direct PDF ink to manufacturer's website.
Specs:
Power Output - 50W × 4 (MAX)
Lineout Output Level - 0.8V (0dB)
Power Supply - 13.2V DC (11-16V)
Dimensions (W × H × D) - 7˝ × 4˝ × 6-1/2˝ (180 × 100 × 165mm)
Display - 6.5˝ wide (16:9), low-glare panel
Display Method
Through - type color filter
Panel Type - Color TFT active matrix
Brightness - 150 (cd/m2)
Drive System
Horizontal - shaped cathode tube
System - NTSC
Screen Aspect Ratio - 4 types
FM TUNER
Frequency Range
87.75 107.9MHz (200kHz step)
Usable Sensitivity
13dBf
50dB
Quieting sensitivity
14dBf
Frequency Response
30 15,000Hz, ±3dB
Stereo Separation
38dB (1kHz)
AM TUNER
Frequency Range
530 1710kHz (10kHz step)
Usable Sensitivity
22µV
CD SECTION
Frequency Response
20 20,000Hz, ±1dB
Wow/Flutter
Below measurable limits
Total Harmonic Distortion
0.03dB (0dB, 1kHz)
EQUALIZER SECTION
Graphic Equalizer
63 12kHz (1/2oct step) ±10dB
Old Sep 24, 2011 | 03:33 AM
Doubledizzle's Avatar
Doubledizzle
would you be willing to sell just the map disc? If so email me at tripleds42@gmail.com. Thanks!
Old Sep 25, 2011 | 01:36 PM
Waiz's Avatar
Waiz
FYI, you just bumped an over two year old thread for an item that is probably already sold
sales@czp
Sep 23, 2019 03:30 PM
Justin100
Nov 29, 2015 03:58 PM
nanotech
Oct 2, 2015 05:02 AM
Tochigi_236
Sep 27, 2015 03:40 PM
