HELP!!!!!!! High Pitch tone after 3'000 RPM?????
Old Feb 17, 2010 | 08:45 PM
~SpInNeY~'s Avatar
~SpInNeY~
Default HELP!!!!!!! High Pitch tone after 3'000 RPM?????
Hi, i just wanna see does anyone have this problem? my car is running normal, and throttle response is the same but just whever after the 3rd gear and 3'000RPM it starts making a very high pitch tone that it never happened b4 at all. ( I have been driving it for 5 yrs already)
also i already checked:
No Leak
intake is fine
electric is good
amp and sub is good
throttle is good just it happens after 3,000 rpm while accelrating but when u release a little is gone till u depress it little harder again.
please help !!!!
thank you very much ...
Old Feb 17, 2010 | 09:06 PM
08nogaroZ's Avatar
08nogaroZ
I read a post on NICO and many people where having this same problem and pretty much pinpointed the Bose stereo system. They were saying that it was like a high pitch noise that you have to really pay attention to or else you wouldn't hear it. Other than that I would have checked the intake as well but you already checked it. Good luck finding the issue.
Old Feb 17, 2010 | 09:08 PM
08nogaroZ's Avatar
08nogaroZ
I had a similar problem now that I remember when I had a mustang. Annoying ringing noise that would get higher pitched the more you accelerated as if there was a bad ground on the stereo/speaker.
Old Feb 17, 2010 | 09:15 PM
~SpInNeY~'s Avatar
~SpInNeY~
thank for the info. but the thing is, i am not using bose and i am using a after market amp and sub. also i have had this set up for like more than 5 yrs but it just started like 2 days ago .....so that's why make it even harder for me to find out what is really happening ...
and that high pitch tone does get very very loud which is even louder than the engine......
Old Feb 17, 2010 | 09:31 PM
08nogaroZ's Avatar
08nogaroZ
oh **** idk about that loud... thats just weird lol good luck
Old Feb 17, 2010 | 09:33 PM
flynbrin's Avatar
flynbrin
VteC just kicked in yo!
Old Feb 17, 2010 | 09:34 PM
08nogaroZ's Avatar
08nogaroZ
vacuum leak maybe?
just guessing
Old Feb 17, 2010 | 09:39 PM
~SpInNeY~'s Avatar
~SpInNeY~
vacuum leak maybe?
just guessing
um.............really donno about that ...but i don't see any leak tho....i guess just wait till it disappears??? but i really hope someone can answer me regarding on this tho ...
Old Feb 17, 2010 | 09:46 PM
35oZephyR's Avatar
35oZephyR
You said aftermarket amp and sub so chances are your RCA's are picking up interference when the signal leaves the head unit.
-double check for loose RCA's
-make sure wires are not run parallel with other power wires.
Most of the time it's just bad RCA grounding on the headunit.
If the problem persists, you might have to ground your RCA's at the headunit or wherever the RCA's output lead to the amp. You can do a quick google search for it, but it involves wrapping like so...
Maybe some audio experts can chime in, but that's the best info I can give you.
Old Feb 17, 2010 | 09:54 PM
~SpInNeY~'s Avatar
~SpInNeY~
it sounds more like a supercharger...hahaha
Old Feb 17, 2010 | 09:55 PM
~SpInNeY~'s Avatar
~SpInNeY~
thank you very much for the info ....but i have been using that set up for 5 yrs but nth happened b4....also why would that affected while i am accelrating tho ????
Old Feb 17, 2010 | 10:03 PM
35oZephyR's Avatar
35oZephyR
This situation may not apply to you but in most cases it's the common "alternator whine". It sounds like a supercharger when you accelerate right?
"The biggest offender of noise in the car audio environment is alternator whine. Alternator whine is caused by a difference in electrical potential (voltage) between two points. It's usually caused by a ground connection that is less than ideal. The main culprits are the amp, the head unit and any intermediate components such as crossovers and equalizers. Basically any component that touches the low level music signal (from RCA cables). It's usually cured by finding the source of the noise entrance and re-grounding that component."
http://www.caraudiohelp.com/newslett...ator_whine.htm
Old Feb 18, 2010 | 06:44 AM
IbarraZ33's Avatar
IbarraZ33
+1 with the alternator / stereo system. Look at the big picture op. We get it after 3k rpm. Have a buddy or someone who knows about audio system.
Old Feb 18, 2010 | 10:05 AM
~SpInNeY~'s Avatar
~SpInNeY~
i really appreciated you guys help.....i will try it tonite and see can i fix it.....wish me luck and will let you know the result.
Old Feb 18, 2010 | 10:20 AM
35oZephyR's Avatar
35oZephyR
Try grounding the RCA's outputs. It can't hurt...
oh btw, do you have an aftermarket head unit as well?
Old Feb 18, 2010 | 12:12 PM
~SpInNeY~'s Avatar
~SpInNeY~
yes i do have an aftermarket head unit also, is that's why ??? but like i said it never happened b4....
Old Feb 18, 2010 | 12:19 PM
fart_canon's Avatar
fart_canon
Old Feb 18, 2010 | 05:09 PM
35oZephyR's Avatar
35oZephyR
My aftermarket headunit was fine for the first couple of weeks before I got alternator whine. Sometimes bad grounding will take a little longer to rear it's ugly head....especially in a car where vibrations and currents are constantly changing.
Old Feb 18, 2010 | 05:40 PM
~SpInNeY~'s Avatar
~SpInNeY~
i just checked all the wires and the head unit (Kenwood KVT- 815 DVD head unit,today .....but it still happens.....now really get me thinking would that be a bad connection of the battery negative side? throttle body ( but i just had it replaced a new one 2 yrs ago)? or vaccum hose leak???
damn the sound is way too loud that i can't just ignore it .....
Old Feb 18, 2010 | 08:55 PM
Hydro_Z's Avatar
Hydro_Z
Sounds like this could be ground noise. Check your headunit's ground wire, RCA cables or amp ground wire if you have a amp. Sure you didn't have the issue before but over time the wires do move around. Happy hunting, I hate ground noise
