Help: ABS Pump keeps running after i shut off car
Old Apr 8, 2010 | 02:16 PM
halfrice's Avatar
halfrice
Default Help: ABS Pump keeps running after i shut off car
Tried posting this in suspension not getting much feedback. Only does this when i turn off the car, pump will continue to run sounds like a vibrating noise, and only does this some times, if it turns on after i turn off my car it will keep running, if it doesnt turn on when i turn off my car its fine. Right now battery is disconnected to make sure i dont burn out the pump. I did use some old brake fluid to get my car home from track day, would it be possible that there is air in the line? or does anyone know where the abs pump ground is, might be a loose ground. If i can think of anything else will post it up, thanks
Old Apr 8, 2010 | 02:55 PM
johnizzlee's Avatar
johnizzlee
This happened to my friend before you should defintely do a flush brake flud and fill it back up with some fresh break fluid DOT 4. Try it out this worked for my friend.
Old Apr 8, 2010 | 03:41 PM
halfrice's Avatar
halfrice
thats the next plan, just waiting for a friend to come over to pump the brake, im glad that it worked out for him and im hoping it will fix my problem.
Chris350z03
Oct 8, 2023 07:19 PM
etkms
Jun 19, 2022 06:30 PM
aarrgghh
May 1, 2022 11:04 AM
Bodyboarder81
Nov 2, 2015 12:17 AM
ThreeFiveZero Z
Sep 12, 2015 04:33 PM
