BBK question / 4 door G35 on 350z
Old Jun 30, 2011 | 08:52 AM
Boneout JZA80's Avatar
Boneout JZA80
Shine Auto Project
Default BBK question / 4 door G35 on 350z
My buddy totalled his car but still has bbk off his 4door G35, i believe they are rotora or brembo im not sure... anyways let me know if they fit or what i need to make them fit on my 350z... thanks
Old Jun 30, 2011 | 10:48 AM
jnathan68's Avatar
jnathan68
Based on research I did a little while ago, the G35 coupe and G35 sedan (pre-2007) and the 350z all use the same BBK part number. Basically, front kits should fit on any and rear kits should fit on any.
I thought I read that certain stoptech kits would only work on 2003-2006 350z that came with the brembo's from the factory however, I cannot confirm. Once you know which brand, probably best to talk to that company to verify or do a test fit.
Old Jun 30, 2011 | 03:28 PM
Chebosto's Avatar
Chebosto
the reason on the ST kit # changins is slightly different piston sizing for brake biasing purposes.
what year G35?
Old Jun 30, 2011 | 04:27 PM
Boneout JZA80
Shine Auto Project
2005 4dr g35 and I own a 2004 base model 350z
Old Jun 30, 2011 | 04:28 PM
Boneout JZA80
Shine Auto Project
I appreciate the feedback fellas good looking out,I also heard it should fit but wanna double check with the folks who know whatsup like cheston john and david etc
Old Jul 1, 2011 | 03:29 PM
dikspiel's Avatar
dikspiel
Chestons Toilet
it will fit fine but the braking bias won't be the same i assume and since you track your car you might want to reconsider
Old Jul 1, 2011 | 09:06 PM
Chebosto's Avatar
Chebosto
Dik is right, but you can compensate on the bias with different front and rear brake pads.
Old Jul 6, 2011 | 03:27 PM
97supratt's Avatar
97supratt
For proper control of the brake bias, I suggest a brake proportioning valve. You can dial in the brake bias. Or the best thing to do is send your brake setup to the manufacturer and they will adjust it for your specific vehicle. My stoptech kit had a specific brake bias designed for my 07' because I only had the front kit without a brembo kit in the rear.
Old Jul 7, 2011 | 04:13 PM
dvo's Avatar
dvo
Do it Ben! you can make it work!
Old Jul 12, 2011 | 01:56 PM
Boneout JZA80
Shine Auto Project
sad story but too good to be true
my boy kept his bbk at a shop (which was his close friend) and they ended up selling it off
there goes my free bbk
Old Jul 12, 2011 | 02:01 PM
jnathan68's Avatar
jnathan68
Ouch! Story without a happy ending.
JjL
East Canada
Jun 12, 2019 03:04 AM
Vigman
Nov 17, 2015 04:34 AM
_koubie_
Sep 20, 2015 06:34 PM
EnjukuRacing
Sep 11, 2015 08:30 AM
