S&R Performance Suspension Bundle Packs! STANCE - BC & MORE!
The Z platform is one of the best handling around! BUT we can always make it better! We build more Z's than anyone else in the region so we know what works! We are taking some of the guess work out of upgrading you suspension and include parts needed for a real and complete install. Check out what we've got to offer!
Stance GR+ Coilovers & SPC Rear Camber Kit w/ Toe Bolts:
The GR+ is the Stance flagship line. It features 15-way damping adjustable monotube shocks, which allows the driver to fine-tune the handling and ride. A separate lower bracket allows the ride height to be adjusted without sacrificing stroke. Spherical bearings are used to give the driver greater feedback. Inverted monotube shocks are utilized on strut types for greater rigidity and heat dissipation. The SPC Kit rear camber kit that we include will allow you to properly set your suspension after installation so that you don't wear your tires and you maximize performance!
CLICK HERE FOR MORE DETAILS AND TO ORDER
BC Racing Coilovers w/ SPC Rear Camber Kit:
The BR model is perfect for street driving and occasional road course duty. With easily accessible adjustment ***** for fine tuning your compression/rebound and separately adjustable ride height, having a performance coilover system couldn’t be any easier. You choose how low or high you want your vehicle, no preset ride height here, and our patented concave lower locking ring keeps it locked in. All of our systems come with pillowball mounts to provide the most feedback possible from your suspension and to sharpen your steering response. BC’s available front and rear camber plates also allow you to get the perfect alignment setup without compromise. All this while providing a strong, attractive looking coilover system.
We include the SPC Rear Camber Kit w/ Toe Bolts so that you can properly configure your coilovers after insallation!
We'll work on putting together more packages to help you all out! Please let me know if you have any other questions.
- Mono-tube shock design
- 30 levels of damping force adjustment, adjust compression/rebound
- Pillowball mounts and adjustable camber plates included (where applicable)
- Adjustable rear camber plates available
- Separate full length height adjustable
- One year warranty
- Rebuildable
thanks for the business folks! Got some locals coming in for some BC Coilover & Stance Coilover lovin!
Looking for something different? Let us know! Let's make a deal and do some business.
this deal has been a huge hit! We've been able to work with many of you all over the country and setup lots of great local Z/G's!
We're still offering the deal so let us know what questions we can answer for you!
Check out this bad mama-jamma on BC's. Such a great stance and rides really well. =)
No matter what your budget, needs or demands are, we can put a suspension package together for you!
Now with a little extra off the top
Not only do you get a discount on the parts but we're now offering a $349 installation, setup and alignment!!!!! This won't be available forever, folks.
