FS: Cobb Springs
Old Oct 21, 2011 | 02:14 PM
jarrodh77's Avatar
jarrodh77
Default Cobb Springs
SOLD SOLD SOLD
I bought these used and had them on for about 5K miles before upgrading to coilovers. I don't know the mileage from the previous owner, but they are in good condition. Spring Rates: F=345, R=438. Drop: F=.75", R=1". These springs are designed without a taper at the bottom like most, so they don't fit the lower spring mounts perfectly. Many people have run them without problems though. I used some polyurethane spring isolators as a precaution to prevent them from sliding around. Seen below is how I used them on my Koni shocks. I'll included the isolators so you can use them if you choose.
$120 shipped OBO.
Located in Nashville, TN for locals.
Old Oct 22, 2011 | 11:44 AM
hairpincorners's Avatar
hairpincorners
any pics of the car with the springs?
Old Oct 22, 2011 | 06:32 PM
jarrodh77's Avatar
jarrodh77
This is on my autocross setup - 275/40/17 tires, which are shorter than OEM diameter in the rear so there is more rear fender gap. Also I had 0.5" cut off the rear spring mounts.
Old Oct 27, 2011 | 01:22 PM
jarrodh77's Avatar
jarrodh77
Bump
Old Nov 6, 2011 | 08:12 AM
jarrodh77's Avatar
jarrodh77
Bump.
Old Nov 21, 2011 | 11:38 AM
jarrodh77's Avatar
jarrodh77
Up top. OBO.
Old Dec 6, 2011 | 07:22 PM
jarrodh77's Avatar
jarrodh77
No interest in one of the few linear rate springs available for the Z? Lots of people run these as-is with zero problems. I was just being extra cautious with the poly isolators since I've had trouble with squeaky suspensions in the past.
Old Dec 9, 2011 | 03:51 PM
shakalaka's Avatar
shakalaka
If i run them as is, i.e without any new struts and all, will I be okay? It's a 03 Z. My winter set up is stock 18" with regular tires and for summers I run 20" rims with 245 up front and 275 tires in the back, if that matters.
Thanks
Old Dec 9, 2011 | 05:18 PM
jarrodh77's Avatar
jarrodh77
Thanks
They'll be fine on the factory struts. The spring rates aren't so much higher than stock that you would have issues with them being under-dampened and bouncy.
Old Dec 24, 2011 | 11:42 AM
jarrodh77's Avatar
jarrodh77
Bump.
Old Dec 24, 2011 | 01:28 PM
vtchang's Avatar
vtchang
i'll take them
Old Jan 3, 2012 | 06:43 PM
jarrodh77's Avatar
jarrodh77
BUMP
Old Jan 9, 2012 | 06:22 PM
mickeyboi's Avatar
mickeyboi
pmed offer =)
Old Jan 9, 2012 | 08:16 PM
mickeyboi's Avatar
mickeyboi
Payment Sent, thanks!
Rowlett
Misc.
Oct 2, 2015 10:38 AM
EnjukuRacing
Sep 30, 2015 06:55 AM
