FS: BNIB Momentum Performance front upper control arms
SOLD
here's some pictures grabbed from somewhere else
The Momentum Performance Nissan 350Z Upper Control Arms offer a wide range of performance benefits for both track and daily driving.
Momentum Performance 350Z Control Arms make use of one-piece billet 7075 aluminum construction, which reduces the weight of these suspension components compared to the stock units while at the same time adding rigidity, strength and response – three important factors for drivers looking to “Push Forward” with their vehicle’s performance. Aurora spherical rod ends also improve the durability of the control arms by removing rubber bushings from the equation.
An additional advantage offered by the Momentum Performance 350Z Control Arms is the four-degree range of camber adjustability that helps track drivers dial in more precise suspension and alignment setups while also allowing street drivers to adjust for lowered ride heights in order to maintain maximum grip and reduce tire wear.
Fitment for 2003-2007 G35 & 2003-2009 350Z
FEATURES
CNC machined, aircraft grade 7075 aluminum
Black anodized design for aesthetics and durability
Aurora rod ends with Grade 8 locking hardware
CNC machined mounting spacers and ball joint adapters
ADVANTAGES
Allows use of factory frame mounts and hardware
+/- 4 Degrees Camber Adjustment
Branded with Momentum Performance logo
FEATURES
ADVANTAGES
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
Justin100
Nov 29, 2015 03:58 PM
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
