FS: Swift springs for coilovers
Old Dec 3, 2012 | 06:56 PM
flyinglumpia's Avatar
flyinglumpia
Default Swift springs for coilovers
Springs are sold, but still have the spacer that will raise the rears if you are almost maxed out.
Also I have some spacers for those peeps that want to raise their rears for the winter and not have the saggy butt look
For the spacer to raise it up more, I will go with 25 shipped.
Thanks for looking. Btw low ballers will be ignored and I believe my prices are pretty fair.
Old Dec 8, 2012 | 09:08 PM
flyinglumpia
bump
Old Dec 11, 2012 | 09:13 PM
SamPappas's Avatar
SamPappas
subbed, may be interested in the front springs. Do you now if they fit all 350z coils, or just BC?
Old Dec 12, 2012 | 06:47 AM
User 42426's Avatar
User 42426
will the rears fit ON the strut of coilovers or is it only supposed to be used as oem style on the spring bucket?
Old Dec 12, 2012 | 06:48 AM
SamPappas's Avatar
SamPappas
^ the seller could correct me here if I'm wrong, but it looks like it's only OEM style for the rear
Old Dec 13, 2012 | 06:43 PM
flyinglumpia
Sorry guys, just checking the forums. Yes I had the rears for the oem set up. As for using them for trues, it might really stiff. What I remember reading is that trues need a softer spring. But you should double check with the coilover manufacture to double check if it can handle that stiff of spring.
As for fitting other coils. They should, you will have to just measure your spring coilovers now. But what it seems like that most of them are usually 8 inchs long and 2.5 inch in diameter.
Old Dec 16, 2012 | 01:54 PM
jarrodh77's Avatar
jarrodh77
I swapped the exact same 200mm x 65mm 13K springs onto the front of my HKS Hipermax coilovers. It was a direct swap, and I only had to adjust the height for the stiffer springs.
Old Dec 16, 2012 | 04:17 PM
SamPappas's Avatar
SamPappas
between Christmas shopping and buying my wheels and coilovers I am dirt poor right now, but if you still have these a few weeks from now I'm buying them.
Old Dec 20, 2012 | 05:55 AM
flyinglumpia
13k sold, 10k pending paypal
Rowlett
Misc.
Oct 2, 2015 10:38 AM
EnjukuRacing
Sep 30, 2015 06:55 AM
