Air Ride Suspension Available at Street Standard
Bringing you the best in Air Ride suspension equipment from brands like:
AND
350Z AirRex Strut and Full Kits
AirREX Suspension System features vehicle specific upper mount, 12 clicks adjustable damper, double convoluted bellow, twist lock compression fitting, fully threaded damper and vehicle specific lower mount. Every AirREX upper mount is CNC machined from 6061 aluminum and then hard anodized. High density polyurethane bushings and or high performance bearings completes the package to ensure exact fitment and durability. These upper mounts not only simplify installation but also improve ride quality, handling, and help provide maximum drop by replacing the bulky OEM upper mount. A 12-way compression and rebound adjustable damper is standard in every AirREX application. Each damper is matched to the air spring for the vehicle application and the user can further adjust for performance or comfort by the simple turn of a ****. High durability 2-ply double convoluted air springs help provide both a comfortable ride at driving height and maximum drop when aired out. The size of the bellow is carefully chosen by AirREX engineers for each application to ensure correct spring rate and proper clearance for the vehicle. Compression fittings are used to ensure a reliable leak free seal when used with 6 mm or .25 inch DOT nylon air tubing. Each AirREX damper is fully threaded to maximize adjustability similar to that of a coil over. Users can easily adjust for maximum drop or for maximum comfort at driving height by simply loosening the lower lock collar and turning the damper and air spring assembly up or down. Every AirREX application includes a vehicle specific lower bracket which is manufacture to exact OEM specification. Every tab or bracket for the hub, spindle, sway bar, brake lines, abs sensor, etc. is present to ensure proper fitment like that of the factory suspension. Some applications will include a high density polyurethane lower mount bushing.
Features:
CNC Machined
Hard Anodized 6061 Aluminum Construction
Includes Vehicle Specific Upper Mount
Includes 12 Clicks Adjustable Damper
Includes Double Convoluted Bellow
Includes Twist Lock Compression Fitting
Includes Fully Threaded Damper and Vehicle Specific Lower Mount
KSpot AirTech kits
Unlike air bag suspension systems of the past where consumers must piece together a complete kit from scratch, often at a compromise to reliability and performance, KSports revolutionary Airtech Suspension System comes as a complete, model specific kit that is 100% bolt-on with no custom modifications needed. Each Airtech Suspension System is fully developed for a particular vehicle with model specific dampers, air compressors, lines, wiring harnesses and instructions.
All Airtech Suspension Systems include KSports monotube coil over dampers with air bags that are pre-installed at the factory. All dampers utilize billet, 6061 aluminum components with zinc electroplated steel shafts that are resistant to salt, rust, dirt and other harmful environmental conditions. The dampers offer 36 levels of adjustment, simultaneously altering rebound and compression. Ride Height adjustment can be performed on the damper itself by using KSports unique adjustable mounting technology, which allows height adjustment without sacrificing suspension travel or ride comfort.
Basic Airtech Suspension System kits come complete with Viair air compressors, all necessary wiring and plumbing materials and instructions. With the convenience of Airtechs bolt-on installation, excellent ride comfort and versatility, KSport has changed the way enthusiasts approach and utilize high quality air bag suspension systems.
If you are looking for an alternate solution to your Air Ride needs, please feel free to contact us with any questions or inquires you may have. Street Standard does competitive price matching! We will do our best to beat any prices you come across! PM or brandon@streetstandard.com for more infomation!
