Headlight help
Old Nov 2, 2007 | 05:21 PM
meatbag's Avatar
meatbag
Default Headlight help
Anyone want to help me take my headlights apart? A little nervous about doing it. Or just give me some pointers.
Old Nov 2, 2007 | 07:19 PM
LegionnaireZ's Avatar
LegionnaireZ
from what i understand you preheat your oven...
prepare a cookie sheet with plenty of oil (olive or PAM (or substitute)
ensure oven is heated to 350 Degrees,
and bake until lightly brown on surface...lol
but seriously i think there is some ovening involved, exact temp. Idunno...
Maybe Acree can chime in... he has done it before.
Old Nov 3, 2007 | 05:35 AM
Eazzy's Avatar
Eazzy
First ----Strip everything off, all wires, bulbs, ballast, rubber u-tube
Next-----Heat the oven to 250 degrees and set the rack on the lowest level to make room for 1 light, cover the rack with tin foil and cut a piece of cardboard that size. (This will be soaked down to set the light on)
Next---- Locate the 6 ? screws that hold the top to the bottom and take out
Next----Place the soaked cardboard on the foil and the light on the cardboard. heat for 12 minutes or so. (I reduce the heat a little)
Next----Get gloves on and a towel for your lap. take it out and start prying the top from the bottom. The urethane will get "stringy" DONT let it get on the lens. If you have to repeat the heating process, do so.
Take everything apart ---do your do--Use a heat gun to reassemble------re seal
Old Nov 3, 2007 | 08:36 AM
batmanesaul's Avatar
batmanesaul
i also wat to do it to mine.. lets set upa meetin g or something i tried but my oven wasnt big enough :/
Old Nov 3, 2007 | 09:45 AM
meatbag's Avatar
meatbag
Thats part of my problem.
Old Nov 3, 2007 | 09:47 AM
meatbag's Avatar
meatbag
When you reassemble do you put then lens on and then run the heat gun around to heat the glue back up?
Old Nov 3, 2007 | 09:55 AM
Eazzy's Avatar
Eazzy
Hard to explain ---it was learned thing from doing a lot ---There are sections that you start at to "bed" it. Then as you work it you start to replace screws. You have to heat and work it and tighten screws and heat more and tighten screws more. Then when its set and totally bedded, you seal it.
Old Nov 3, 2007 | 02:36 PM
meatbag's Avatar
meatbag
These are G35 lights if it makes any difference.
Old Nov 3, 2007 | 05:21 PM
batmanesaul
well if you have a heat gun i think that will work too just as long as we are carefull with it...
Uriyo_
Sep 8, 2021 08:46 AM
Dsowe
Feb 17, 2021 10:38 AM
JGee450
Sep 30, 2015 04:32 AM
TrboMike
North East
Sep 28, 2015 06:36 PM
Kilroy.Bukowski
Sep 26, 2015 11:24 AM
