Buying an extra ECU / black box questions...
Old May 11, 2005 | 07:08 AM
DomZ's Avatar
DomZ
Default Buying an extra ECU / black box questions...
Ok, so now that I'm thoroughly discouraged from getting a Unichip, my only option is TS or AAM reflash (can't get emanage, can't hack the wiring harness under warranty) I want to know if I can purchase a seperate ECU from a wrecked 5AT and plug it into my harness...and also, is the black box built into the ECU? I want to know, incase anything happens at the track, I will swap the stock ECU back in and return my car to stock before I bring it in...
Old May 11, 2005 | 07:13 AM
JCat's Avatar
JCat
You do not need to cut the ECU wiring harness. Get a jumper (that you can spice into):
But you might read this thread first:https://my350z.com/forum/engine-and-drivetrain/122214-how-the-ecu-works-and-what-needs-to-be-overcome-for-na-gains.html
Old May 11, 2005 | 07:18 AM
DomZ's Avatar
DomZ
But you might read this thred first:https://my350z.com/forum/showthread.php?t=122214
Where can I find one of these? If that jumper is easily availible, I have no problem buying eManage and E01
edit: I read Sentry's thread..but I need something to adjust my AF maps once I throw intake/spacer/headers/high flows/pulley on right?
ZU L8R's Avatar
ZU L8R
Viper Sellout
I think the ecu's are vin coded. I think you would need to get a dealership to program your vin into the ecu. There was another thread about this very thing.
Old May 11, 2005 | 08:44 AM
ajk4's Avatar
ajk4
i originally had my ecu flashed for na mods. then i got a spare and technosquare copied my immobilizer data and flashed the blank ecu for n2o for $300. here is a link to the ecu harness.
http://www.courtesyparts.com/Merchan...ct_Code=ASW180
Old May 11, 2005 | 09:42 AM
jkoc's Avatar
jkoc
seems like a ts limited reflash + apexi safc2 might be handy
hulkout
Tuning
Sep 30, 2015 12:33 PM
