AAM Review - UTEC Engine Management System
Old Dec 9, 2005 | 12:09 PM
  #81
BlackTuner's Avatar
BlackTuner
Originally Posted by Havok_RLS2
Thats a good point. You should try 95 south.
Would you happen to know what the expected gains are from a stock Z using the pre programed UTEC map?
The pre-programmed map should make roughly about 10whp. The current base map isn't meant to be a big power maker. With every car being different, we are best suited to leave some power on the table, to keep some cars from being tuned on the edge.
On my buddies 2005 G35 coupe we were able to make about 270whp not spend any time on tuning, just loading a map and altering it slightly. His car baselined just shy of 259whp.
Thanks,
Jermaine@turboxs.com
Old Dec 9, 2005 | 12:21 PM
  #82
trey.hutcheson's Avatar
trey.hutcheson
Any specifics on raising the rev limiter on the 05+?
Old Dec 9, 2005 | 12:24 PM
  #83
BlackTuner's Avatar
BlackTuner
Originally Posted by BlackTuner
.... revving the 05 motor above it's factory rev limiter doesn't seem to make a difference. We have the hardware on the UTEC to control rev limit the software to do it will be release at a later date along with VTC control. ...
Thanks,
From a previous post.
Old Dec 9, 2005 | 12:29 PM
  #84
iamgus_gus's Avatar
iamgus_gus
lets see these numbers off the Z with bolt ons
Old Dec 9, 2005 | 01:23 PM
  #85
trey.hutcheson
That's great. But could you elaborate a bit on the "doesn't seem to make a difference" part?
Old Dec 9, 2005 | 01:36 PM
  #86
Netko350Z's Avatar
Netko350Z
+1 Need to see the number!!! That's all that matters to me!!!
I am about to just call AAM!!!!
#'s #'s #'s!!!!!
Old Dec 9, 2005 | 03:17 PM
  #87
BlackTuner's Avatar
BlackTuner
#'s #'s #'s!!!!!
2004 350Z
Blue Line Mods - TurboXS Intake & Test Pipes
Green Line (or yellow) Mods - TurboXS Intake, Test Pipes & Tuned UTEC
Light Blue Mods - TurboXS Intake, Test Pipes, APS Tall Boy Plenum & Tuned UTEC
I will post plots with our exhaust on Monday.
Thanks,
Jermaine~
Old Dec 9, 2005 | 03:28 PM
  #88
iamgus_gus's Avatar
iamgus_gus
decent gains
Old Dec 9, 2005 | 05:23 PM
  #89
kosmic's Avatar
kosmic
Looks like we're going to see some pretty strong NA cars, especially once the VTC control is added. The FI guys have got to be pretty excited, too. (subscribing)
Old Dec 9, 2005 | 06:09 PM
  #90
paranormal's Avatar
paranormal
Evil Boy 4 LIFE
what mods are on that g35? thats some beefy na numbers
Old Dec 10, 2005 | 06:22 AM
  #91
Havok_RLS2's Avatar
Havok_RLS2
NICE!
Old Dec 10, 2005 | 08:20 AM
  #92
plumpzz's Avatar
plumpzz
-.- bumping UTEC up in my list. It will work fine on an 05 right? Im not concerned about speed limiter, jut rev limiter (w/ cams ofcourse)
Old Dec 10, 2005 | 10:28 AM
  #93
JoneZZZ's Avatar
JoneZZZ
Subscribing.........
Old Dec 10, 2005 | 11:16 AM
  #94
SirZaLot's Avatar
SirZaLot
Can UTEC do whatever ECU reflash can do?
Old Dec 10, 2005 | 11:23 AM
  #95
illZ's Avatar
illZ
and a lot more.
Old Dec 10, 2005 | 12:02 PM
  #96
iamgus_gus's Avatar
iamgus_gus
its pretty much a stand alone system. it can more then ull need
Old Dec 10, 2005 | 03:15 PM
  #97
nissansource's Avatar
nissansource
how about this... im ready to buy my Utec who do i buy from so i can get this thing ASAP this TN car is detonating I also want the wideband option
Old Dec 10, 2005 | 03:55 PM
  #98
XBS's Avatar
XBS
Veteran
talk to mike at altered atmosphere PM him her is very knowledgable and can hook you up
Old Dec 12, 2005 | 05:19 AM
  #99
Mike@Altered's Avatar
Mike@Altered
If you'd like shoot me an e-mail MikeM@alteredatmosphere.com. We are put together a package for our 05+ customers to include an immensly disconted ECU rev-limit flash (so you can set the rev-limiter) with the UTEC.
Hope this helps,
Old Dec 12, 2005 | 06:26 AM
  #100
zillinois's Avatar
zillinois
Looks like a really great system. It just moved to the top of my mod list.
Maybe someone can educate me on the VTC issue, but isn't that mainly for gas mileage when driving easily and power when driving hard and would have literally no effect on power at WOT after it phased? In other words, isn't the cam phasing just going to be maxed out at heavy load if the ECU detects WOT? Plus that fact that very few people I've ever met could tell you which way to adjust cam phasing to make an improvement. Just something to consider. I may be way off base, just let me know and I'll crawl back into my cave.
