Base Map
Old Jun 17, 2006 | 10:35 AM
chickmagnet's Avatar
chickmagnet
Default Base Map
Does Anyone Have The Base Mapp For The E Manage Blue And Can You Post It And Send It To Me
Thanks
Old Jun 18, 2006 | 12:06 AM
aalzuhair's Avatar
aalzuhair
Maybe I can help you. But I need to know:
1) What do you have on the car?
2) What kind of fuel system?
3) Are you using a MAP sensor for mapping or MAF?
4) Do you have the ign. harness hooked up?
Old Jun 18, 2006 | 12:11 AM
aalzuhair's Avatar
aalzuhair
Sorry, I just read your sig! It seems that your car is stock.
If you install the e-manage and set the parameters you will be just fine, because it will run the stock ecu with no changes, but make sure that all maps are clear.
Later all you need to do is add fuel or take out fuel as you see fit at the RPM/load point that you want.
Old Jul 5, 2006 | 01:53 PM
DiabieZ's Avatar
DiabieZ
I also need the base map for the emange blue, i hit update on the E-01 and now have nothing. I desprately need this map as i am trying to move (by trailering the car) and don't want to start the car with a blank emanage.
2ndchanceZ
Oct 26, 2015 08:03 PM
350z82
Oct 1, 2015 06:25 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
