UTEC MAP sensor question???? what value???
Old Aug 14, 2006 | 07:29 PM
QuadCam's Avatar
QuadCam
Default UTEC MAP sensor question???? what value???
In the UTEC, you have to enter the MAP parameters from the Sensor card.....the problem is that I have 8 values on the card and none of them are what is asked for by the UTEC.
Which values do I use???
MAP Sensor Calibration Card
__________________________
PSI Output
Cal1 Input 1131 Cal1 Output 736 (or maybe 7.36 )
Cal2 Input 1714 Cal2 Output 20.53
BAR Output
Cal1 Input 806 Cal1 Output 000
Cal2 Input 1447 Cal2 Output 100
which do I use? PSI or BAR? Input or output? Cal1 or Cal2?
Old Aug 15, 2006 | 06:07 AM
QuadCam's Avatar
QuadCam
Bueller? Bueller?
Old Aug 15, 2006 | 06:51 AM
BlackTuner's Avatar
BlackTuner
The Gradient and Intercept entered in your special constants will work fine. You do not need to use the values on the car.
Thanks,
Jermaine@turboxs.com
Old Aug 15, 2006 | 07:16 AM
mistaboosta's Avatar
mistaboosta
there is a calculator for those values to fit which can be downloaded from a topic that I'd previously posted.
Old Aug 15, 2006 | 09:20 AM
QuadCam's Avatar
QuadCam
i was only concerned because i was getting a reading of -0.5 psi with the MAP sensor in free-air. I assumed that it should read 0 since I live at sea level
Old Aug 15, 2006 | 02:16 PM
Audible Mayhem's Avatar
Audible Mayhem
My350z
there is a calculator "somewhere" for those figures, but i couldnt find it, i think there is a special TXS page somewhere !! hehehe
Old Aug 15, 2006 | 03:51 PM
Julian@MRC's Avatar
Julian@MRC
Thanks,
Listen to only this man....He IS Turbo XS...
Old Aug 16, 2006 | 06:55 AM
QuadCam's Avatar
QuadCam
here it is:
https://my350z.com/forum/attachment....4&d=1150869074
i haven't fiddle with the UTEC much yet. I did plug my numbers into calculator and it gave values of 165 and 110. What are the default values?
2ndchanceZ
Oct 26, 2015 08:03 PM
