Utec keeps retarding timing
Old Aug 29, 2006 | 06:19 AM
down_shift's Avatar
down_shift
Default Utec keeps retarding timing
Even on "0" the Utec thinks my car is knocking and keeps retarding the timing on my turbonetics G. Anyone know what's up with that? I take the Utec out and run reflash and the car runs fine on the Dyno. I even turned off the knock sensor and the Utec keeps wanting to retard timing.. Did I get ANOTHER bad unit?
Old Aug 29, 2006 | 06:48 AM
Kenk2's Avatar
Kenk2
Professional
Can you post some logs? Do you have the tuner wideband?
Old Aug 29, 2006 | 02:45 PM
GTT's Avatar
GTT
i believe there is something in the options to close this features.
Old Aug 29, 2006 | 08:38 PM
SmokyTyrz's Avatar
SmokyTyrz
Knock sensitivity too high for FI? Have you been tuned by a pro already?
Old Aug 30, 2006 | 01:37 AM
BrokeZ's Avatar
BrokeZ
are you talking about the 0% load column? Depending on what your parameters are, you might actually be knocking. I have found the utec knock feature to be pretty decent. Maybe you could paste a log for us to see... then we can try to pinpoint the problem.
Old Aug 30, 2006 | 06:29 AM
Julian@MRC's Avatar
Julian@MRC
Do you have a light weight flywheel?
Loose Exhaust?
What is your knock sensitivity set to?
Old Aug 30, 2006 | 11:29 AM
down_shift's Avatar
down_shift
The tuner said it's turned down to 1/3 of what it was before.
I have a the Nismo Fly installed..
Old Aug 30, 2006 | 12:06 PM
QuadCam's Avatar
QuadCam
downshift,
which engine have? I have a revup, TN and UTEC. I keep getting knock counts even with a Fat A:F and REALLY conservative timing. The stock ECU is picking up the knock....its timing isn't changing. It happens in the 4500-5500 range. Could that be the range where the ECU is shifting the cam timing? could the UTEC be picking up that noise?
Old Aug 30, 2006 | 03:14 PM
Julian@MRC's Avatar
Julian@MRC
Originally Posted by QuadCam
downshift,
look at a data log of what the stock ECU is doing, and see if where its knocking the stock ECU is pulling timing as well.
Old Aug 30, 2006 | 03:19 PM
Kenk2's Avatar
Kenk2
Professional
^ +1
If its not pullin timing, have the utec do it. My stock timing was knockin at +27 from 6000 rpm's to 7000.. Pulled stock timing -1 and that took care of it.. Try that it should work..
Old Aug 30, 2006 | 03:27 PM
Julian@MRC's Avatar
Julian@MRC
Originally Posted by Kenk2
^ +1
In the datalog you will see 2 columns, timing that the ECU WANTS to run, and timing the the UTEC is running....If his UTEC is pulling timing and the same spot the Stock ECU is not pulling timing then you know it is not real knock. this is best observed in several back to back runs and saved datalogs. The stock ECU will retard it's own timing, to an extent..We really need datalogs to help you out.
Old Aug 30, 2006 | 03:35 PM
QuadCam's Avatar
QuadCam
I have looked at both. in most cases, the stock ECU does nothing. But the UTEC is registering a knock count of "8."
I have seen some occasions where the UTEC is not registering any knock, but the ECU is retarding timing by about 6 degrees. odd, huh?
Old Aug 30, 2006 | 04:00 PM
Julian@MRC's Avatar
Julian@MRC
your knocking, or picking up tons of noise from the flywheel..I would rtetune the car, what is your A/F and timing set at where it knocks and what are your mods..Keep in mind, the 4500-4700 rpm area is where the car makes peak TQ, you want your timing and A/F to be really perfect in that area.
Old Aug 30, 2006 | 05:52 PM
QuadCam's Avatar
QuadCam
I have a stock flywheel. I figured that they are quiter than the 1 piece aftermarket flywheels.
BTW, Thanks for all your responses. I definately appreciate it.
Old Aug 31, 2006 | 06:23 AM
chimmike's Avatar
chimmike
isn't there a way to shield the knock sensor wire to prevent interference from a flywheel? I intend to run a fidanza and don't want to come into issues with this!
Old Aug 31, 2006 | 09:09 AM
Kenk2's Avatar
Kenk2
Professional
So is it safe to say that my ECU IS NOT pullin timing based on this log and the log on the next post??
Code:
5984 -17.8 4.33 100  80    01   13.41 +24.9   66.7 ECU.   -4.9     4.17  12.56
 6006 -17.8 4.37  98  80    04   13.35 +24.8   65.0 ECU.   -4.8     4.17  12.49
 6027 -17.8 4.39  98  80    05   13.57 +25.8   67.1 ECU.   -4.8     4.15  12.45
 6049 -17.8 4.37  98  80    07   13.34 +24.7   67.2 ECU.   -5.0     4.15  12.42
 6038 -17.8 4.35  98  80    01   13.25 +25.9   66.5 ECU.   -4.9     4.17  12.37
 6082 -17.8 4.33  98  80    04   13.23 +25.7   66.4 ECU.   -5.1     4.19  12.39
 6093 -17.8 4.37  98  80    08   13.21 +25.9   65.9 ECU.   -5.0     4.19  12.34
 6093 -17.8 4.39  98  80    01   13.16 +25.7   67.3 ECU.   -5.1     4.17  12.30
 6127 -17.8 4.37  98  80    05   13.14 +25.7   66.9 ECU.   -5.2     4.17  12.27
 6207 -17.6 4.39  98  80    03   13.26 +25.6   67.9 ECU.   -5.2     4.13  12.27
 6150 -17.8 4.39  98  80    02   13.26 +26.8   68.0 ECU.   -5.2     4.19  12.34
 6207 -17.8 4.43  98  80    03   13.21 +25.7   67.6 ECU.   -5.3     4.15  12.42
 6184 -17.8 4.43  98  80    04   12.98 +25.7   67.3 ECU.   -5.4     4.17  12.42
 6230 -17.8 4.43  98  80    03   12.98 +26.9   67.1 ECU.   -5.5     4.21  12.42
 6195 -17.8 4.41  98  80    03   12.89 +26.9   66.7 ECU.   -5.3     4.13  12.37
 6172 -17.8 4.37  98  80    05   12.91 +26.8   67.1 ECU.   -5.5     4.19  12.39
 6289 -17.8 4.43  98  80    05   12.87 +26.8   67.1 ECU.   -5.5     4.13  12.45
 6277 -17.6 4.41  98  80    09   12.82 +26.9   67.0 ECU.   -5.5     4.17  12.52
 6253 -17.8 4.45  98  80    01   13.02 +26.9   67.9 ECU.   -5.6     4.15  12.56
 6265 -17.8 4.45  98  80    01   12.77 +26.7   66.7 ECU.   -5.6     4.19  12.56
 6265 -17.8 4.37  98  80    03   12.96 +26.8   67.2 ECU.   -5.5     4.17  12.53
 6313 -17.8 4.45  98  80    03   12.93 +26.7   68.2 ECU.   -5.6     4.15  12.49
 6510 -17.8 4.49  98  80    05   12.62 +26.7   67.1 ECU.   -5.5     4.19  12.53
 6337 -17.8 4.47  98  80    04   12.64 +26.6   66.7 ECU.   -5.5     4.21  12.59
 6397 -17.8 4.41  98  80    01   12.80 +26.8   68.3 ECU.   -5.5     4.17  12.61
 6361 -17.8 4.43  98  90    09   12.77 +26.8   68.0 ECU.   -5.4     4.21  12.61
 6422 -17.8 4.41  98  80    04   12.54 +26.7   66.7 ECU.   -5.4     4.21  12.61
 6397 -17.6 4.43  98  80    05   12.50 +26.8   67.9 ECU.   -5.4     4.19  12.61
 6435 -17.8 4.47  98  80    03   12.48 +27.6   66.8 ECU.   -5.4     4.21  12.59
 6472 -17.8 4.41  98  80    05   12.64 +27.8   68.2 ECU.   -5.3     4.21  12.56
 6459 -17.8 4.41  98  80    01   12.62 +27.8   66.4 ECU.   -5.3     4.19  12.56
 6485 -17.8 4.45  98  80    01   12.57 +27.7   68.4 ECU.   -5.3     4.21  12.53
 6535 -17.8 4.43  98  80    00   12.57 +27.9   67.7 ECU.   -5.3     4.19  12.52
 6497 -17.8 4.47  98  80    03   12.55 +27.8   67.6 ECU.   -5.3     4.17  12.52
 6548 -17.8 4.49  98  90    01   12.50 +27.8   67.6 ECU.   -5.2     4.21  12.56
 6561 -17.8 4.43  98  90    00   12.50 +27.8   69.1 ECU.   -5.2     4.21  12.56
 6561 -17.8 4.45  98  90    02   12.64 +28.7   68.6 ECU.   -5.2     4.25  12.52
 6574 -17.8 4.45  98  90    03   12.41 +27.9   69.2 ECU.   -5.2     4.15  12.52
 6535 -17.8 4.49  98  90    02   12.57 +27.6   68.9 ECU.   -5.2     4.25  12.46
 6653 -17.8 4.41  99  90    00   12.36 +27.6   69.7 ECU.   -5.2     4.21  12.42
 6666 -17.6 4.47  99  90    02   12.32 +28.8   68.4 ECU.   -5.2     4.21  12.46
 6680 -17.8 4.41  99  80    02   12.30 +28.8   68.0 ECU.   -5.3     4.25  12.46
 6706 -17.8 4.47  99  80    00   12.29 +28.7   68.3 ECU.   -5.3     4.19  12.46
 6706 -17.8 4.39  98  80    00   12.29 +28.8   67.7 ECU.   -5.3     4.21  12.46
 6706 -17.8 4.47  98  80    00   12.23 +28.6   68.0 ECU.   -5.3     4.19  12.49
 6666 -17.8 4.45  98  80    00   12.20 +28.9   67.6 ECU.   -5.3     4.15  12.52
 6693 -17.8 4.47  98  80    00   12.16 +28.5   68.0 ECU.   -5.3     4.21  12.53
 6734 -17.8 4.43  98  80    00   12.16 +28.8   68.0 ECU.   -5.3     4.19  12.56
 6761 -17.8 4.45  98  90    01   12.18 +28.8   68.7 ECU.   -5.3     4.19  12.56
 6706 -17.8 4.39  98  90    01   12.13 +29.0   67.7 ECU.   -5.3     4.19  12.56
Old Aug 31, 2006 | 09:10 AM
Kenk2's Avatar
Kenk2
Professional
Code:
6016 -17.8 4.37  99  80    00   13.57 +25.9   68.0 Ecu.   -4.9     4.13  12.52
 6027 -17.8 4.37  99  80    00   13.73 +25.9   69.2 Ecu.   -5.0     4.11  12.56
 6060 -17.8 4.39  99  80    00   13.48 +25.9   68.1 Ecu.   -4.9     4.11  12.56
 6105 -17.8 4.39  99  80    00   13.23 +25.8   67.1 Ecu.   -4.9     4.13  12.59
 6105 -17.8 4.35  99  80    00   13.39 +25.8   67.6 Ecu.   -5.1     4.19  12.56
 6138 -17.8 4.43  99  80    00   13.14 +26.8   66.5 Ecu.   -5.2     4.17  12.56
 6150 -17.8 4.45  99  80    01   13.26 +26.9   68.0 Ecu.   -5.2     4.19  12.53
 6161 -17.8 4.41  99  80    02   13.26 +25.8   67.6 Ecu.   -5.2     4.17  12.56
 6207 -17.6 4.45  99  80    01   13.07 +26.8   68.1 Ecu.   -5.3     4.21  12.56
 6207 -17.6 4.43 101  80    03   13.19 +26.8   68.3 Ecu.   -5.5     4.13  12.59
 6207 -17.6 4.37  98  80    02   12.75 +27.7   67.1 Ecu.   -5.4     4.19  12.61
 6242 -17.8 4.47  99  80    02   12.89 +27.8   66.8 Ecu.   -5.5     4.15  12.59
 6253 -17.8 4.43  99  80    02   12.87 +27.8   67.0 Ecu.   -5.5     4.19  12.59
 6230 -17.6 4.49  99  80    01   12.82 +27.7   67.1 Ecu.   -5.6     4.19  12.59
 6325 -17.8 4.43  99  90    02   12.80 +27.8   68.2 Ecu.   -5.5     4.25  12.59
 6325 -17.8 4.47  99  90    01   13.14 +27.6   67.7 Ecu.   -5.5     4.19  12.61
 6313 -17.8 4.43  99  90    01   12.93 +27.7   67.8 Ecu.   -5.5     4.15  12.61
 6349 -17.8 4.45 100  80    02   12.68 +28.0   66.4 Ecu.   -5.5     4.21  12.61
 6373 -17.8 4.43  98  80    01   12.80 +27.8   67.4 Ecu.   -5.4     4.23  12.59
 6385 -17.8 4.45  99  80    00   12.82 +27.8   67.9 Ecu.   -5.4     4.21  12.56
 6435 -17.8 4.47  99  80    00   12.77 +27.8   68.1 Ecu.   -5.5     4.15  12.61
 6422 -17.8 4.50  99  90    04   12.54 +27.9   67.4 Ecu.   -5.4     4.17  12.61
 6459 -17.6 4.45  99  90    04   12.68 +27.6   68.0 Ecu.   -5.3     4.17  12.64
 6485 -17.8 4.45  99  90    03   12.84 +29.0   68.9 Ecu.   -5.4     4.17  12.61
 6485 -17.8 4.50  99  90    01   12.62 +28.9   67.7 Ecu.   -5.4     4.19  12.59
 6497 -17.8 4.45  99  90    02   12.61 +28.8   67.8 Ecu.   -5.3     4.21  12.61
 6497 -17.6 4.47  99  90    01   12.52 +28.8   67.8 Ecu.   -5.3     4.21  12.61
 6535 -17.8 4.39  99  90    01   12.52 +28.7   68.1 Ecu.   -5.2     4.27  12.67
 6523 -17.8 4.45  99  90    00   12.68 +28.9   69.2 Ecu.   -5.2     4.21  12.61
 6535 -17.8 4.47  99  80    00   12.48 +28.8   68.3 Ecu.   -5.2     4.15  12.59
 6561 -17.8 4.45  99  80    00   12.43 +29.3   68.4 Ecu.   -5.2     4.21  12.56
 6600 -17.6 4.45  99  90    00   12.57 +28.6   68.9 Ecu.   -5.2     4.23  12.52
 6574 -17.8 4.45  98  90    00   12.36 +28.9   68.8 Ecu.   -5.2     4.17  12.56
 6613 -17.8 4.47  99  90    00   12.38 +29.3   68.1 Ecu.   -5.3     4.21  12.52
 6613 -17.8 4.45  99  90    01   12.32 +28.7   67.9 Ecu.   -5.3     4.15  12.52
 6653 -17.8 4.47  99  90    01   12.25 +29.3   67.8 Ecu.   -5.3     4.23  12.52
Old Aug 31, 2006 | 11:40 AM
QuadCam's Avatar
QuadCam
how did you drive through all of that? with the UTEC majorly retarded timing? were you getting alot of popping or backfiring? your plugs were firing 5 degrees AFTER top dead center!
Old Aug 31, 2006 | 11:54 AM
Kenk2's Avatar
Kenk2
Professional
Me?
UTEC wasnt retarding timing at all.. it was set to ECU..
Old Aug 31, 2006 | 01:34 PM
QuadCam's Avatar
QuadCam
Me?
WOOPS!!! I was looking at the wrong column!
