O2 install and does ne1 know where I can get the little plugs for the TurboXS Tuner?
Old Aug 30, 2006 | 04:30 PM
SmokyTyrz's Avatar
SmokyTyrz
Default O2 install and does ne1 know where I can get the little plugs for the TurboXS Tuner?
I'm getting an AFR gauge and would like to try hooking it up to the TXS Tuner WB's 0-5v output. This output is a female two-pin connector.
The DB15 has another of these 2-pin female connectors (for the VW sensor??). But I need the male variant of this connector.
What I want to do is be able to cleanly plug my O2 gauge into this 5v output on the TunerWB. It has been written here, as reported indirectly from TurboXS that the AEM UEGO Display Gauge should work fine with the 5v output on the Tuner.
But don't most O2 gauges have three wires? 1 for 12v, 1 ground, and 1 for O2 signal? Assuming this is standard, which of these two wires gets plugged into the tuner? (Ground and signal) or (12v and signal)?
Hope someone knows...
thx
-Smoky
2ndchanceZ
Oct 26, 2015 08:03 PM
350z82
Oct 1, 2015 06:25 PM
35reilly
Sep 28, 2015 07:42 AM
