UTEC knock sensitivity too high? look at log please
Old Sep 15, 2006 | 09:08 PM
QuadCam's Avatar
QuadCam
Default UTEC knock sensitivity too high? look at log please
Have a look at this log.
I have been having issues with timing and knock on the UTEC. Hell, I can't even get over 6000 rpms. The UTEC is sensing knock and pulling timing. I know that it is really rich over 5000 and I have since leaned it out. Look at all the knocks the UTEC is picking up, but it seems that the stock ECU isn't picking it up. The stock ECU is retarding timing. I have the timing all the way back to 8-9 degrees and the power sucks over 5000 and it is still picking up alot of knock!!!
It has been the 4000-6000 range where all this occurs. The UTEC knock sensitivity in those ranges are:
4000-5000 = "85"
5000-6000 = "80"
I haven't messed with the knock settings other than changing the threshhold count to "3."
File Type: txt
Old Sep 16, 2006 | 12:04 PM
SmokyTyrz's Avatar
SmokyTyrz
What is the result when you control only the MAF offset (for AFR) with the UTEC, but let the ECU continue to handle timing?
Old Sep 16, 2006 | 01:02 PM
QuadCam's Avatar
QuadCam
there is no way I am going to redo all of my maps to try using MAF Pull up/down. anyway, you'll max out the maf pretty quickly on boost.
I am using the MAP functions to control fuel and timing.
Old Sep 16, 2006 | 07:35 PM
SmokyTyrz's Avatar
SmokyTyrz
Ah sorry. Didn't see a list of mods so I didn't know (and didnt notice the title of the file).
Do you have a lightened flywheel?
Old Sep 16, 2006 | 07:41 PM
QuadCam's Avatar
QuadCam
no, stock flywheel and clutch.
Old Sep 17, 2006 | 06:12 AM
Kenk2's Avatar
Kenk2
Professional
Pull the sensitivity back a little.. My 5-6000 RPM range is set to like '60'. Also what gear are you loggin in?
Old Sep 17, 2006 | 06:32 AM
QuadCam's Avatar
QuadCam
that particular log was in 3rd gear.
It's a lottle hard to do the 4th or 5th gear logs on public streets.
Old Sep 17, 2006 | 06:43 AM
Kenk2's Avatar
Kenk2
Professional
I hear ya for sure, thats why I do them on the freeway..
If I were you I would try getting on the freeway, and doing some logs at 100% TPS in 4th gear.. Its hard to nail down your A/F when in 3rd.. Also pull the sens. back to like 65 and give it a whirl..
Old Sep 17, 2006 | 06:57 AM
QuadCam's Avatar
QuadCam
I can do the freeway, but once I get on the freeway, it is like 10 miles 'til the next exit. kinda sux!
Old Sep 17, 2006 | 08:01 AM
eagletanggreen's Avatar
eagletanggreen
Got Track!!!!!
I had the same problem with my car, Sharif just raised the knock sensor a bit, no problem runs like a champ.
Old Sep 17, 2006 | 09:21 AM
QuadCam's Avatar
QuadCam
would you mind sharing what you have your knock sensitivity number are? I don't want to adjust it too low.
Old Sep 17, 2006 | 09:32 AM
Audible Mayhem's Avatar
Audible Mayhem
My350z
i have mine high like i have stated before but tons of people have it at about
90 80 75 65 55 55
i have seen this on many occasions on people parameters..
Old Sep 17, 2006 | 09:39 AM
QuadCam's Avatar
QuadCam
the funny thing is I have never heard my car ping when I am getting these reports. That is understandable......here's a strange one though:
I used to have "ecu" set on some of my timing points in the lower rpms of the lower load columns. One time, I hit 5 psi at about 2500 rpm while the ECU was still controlling the timing and I could hear the pinging very clearly. Funny thing is that neither the UTEC nor the ECU picked it up, nor did it pull any timing!!! Needless to say, I went back and made alot of changes to the lower rpm timing points.
Old Sep 17, 2006 | 12:56 PM
eagletanggreen
Got Track!!!!!
I'll go check as soon as I get back from dinner, I was at the track all day, my wife is pissed!
Old Sep 18, 2006 | 09:08 AM
Kenk2's Avatar
Kenk2
Professional
If you have it set to 'ECU' the utec isnt going to pull timing.. The ECU should pull it tho.. Wierd..
2ndchanceZ
Oct 26, 2015 08:03 PM
Alexreyes
Sep 30, 2015 11:30 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
