Need a tuning expert{simple problem}
Old Sep 30, 2006 | 03:00 PM
davidf's Avatar
davidf
Default Need a tuning expert{simple problem}
So I installed new denso plugs today and while I had it down I decided to clean the pvc valve and TB at the same time. So you'll know I opened the TB servo maybe 5/6 times manually to wipe out the crud with a rag and brake cleaner {no I did not spray any in the TB}. I'm very careful to make sure everything goes back perfectly. Now the problem: as I pull up to a redlight the tach. sets at 12/1500 rpm's for 2/3 seconds then drops to 1000 rpm's. The car use to idle steady at 6/700 rpm's. I stumped. Any suggestions are very appreciated. BTW it does this with AC on or off!
Old Sep 30, 2006 | 10:50 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
Try throttle position relearning ?
http://www.technosquareinc.com/350reset.htm
Old Oct 1, 2006 | 08:16 AM
davidf's Avatar
davidf
Is that something it will learn on it's own?
Old Oct 1, 2006 | 08:17 AM
davidf's Avatar
davidf
Opp's ignore the above post, read the link. Thanks.
Old Oct 1, 2006 | 11:06 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
Did you do it? Did it help?
Uriyo_
Sep 8, 2021 08:46 AM
Dymsi
Sep 29, 2015 11:32 AM
