How to raise idle with Vortech?
Old Oct 7, 2006 | 02:43 PM
RA11325's Avatar
RA11325
Default How to raise idle with Vortech?
Hey guys, i tried to raise my idle today using the cipher software but my car will not accept the changes...I was told this is likely due to the presence of the vortech piggy back. So how the hell am i going to raise my idle?
Old Oct 7, 2006 | 08:06 PM
QuadCam's Avatar
QuadCam
the piggy back shouldn't affect it.
I have only heard of reflashed ECUs not being able to work with the Cipher.
If all else fails, drill a small hole in your throttle body. It does work, though!
Old Oct 7, 2006 | 08:14 PM
Mr_pharmD's Avatar
Mr_pharmD
if u have a 2004.5 then it wont work. u need to reflash youre ecu
Old Oct 8, 2006 | 06:44 AM
RA11325's Avatar
RA11325
I have an 04.5, fudge.
Old Oct 9, 2006 | 08:05 AM
skyydiver's Avatar
skyydiver
That's strange, because I am looking at the Cipher V1.03 owners manual, and on page 12, it shows that you can.
Hey Jared at UpRev...can you comment on this.
Thanks,
Joe
Old Oct 9, 2006 | 08:06 AM
chimmike's Avatar
chimmike
again, many 04 models, you cannot raise the rev limiter. This is a known thing.
Old Oct 10, 2006 | 05:13 AM
Mike@Altered's Avatar
Mike@Altered
Everyone is correct, the Cipher is a great tool but it does not raise the idle on the 2004.5's. The idle can be raised through an ECU Flash such as this http://www.alteredatmosphere.com/mm5...y_Code=350Z_EM .
Hope this helps,
Old Oct 27, 2006 | 04:38 PM
BobbyRitz's Avatar
BobbyRitz
Yes, it is a known thing. My question is should 2004.5 Cipher owners have to pony up for a reflash if they bought it to raise their idle RPM?
Old Oct 27, 2006 | 05:44 PM
Mike Wazowski's Avatar
Mike Wazowski
Why shouldn't they? Only makes sense if they want to raise their idle they get a reflash since uprev does not have the software released to do that yet.
Old Nov 29, 2006 | 10:25 AM
OldManZ350's Avatar
OldManZ350
Try increasing the Value the 1000rpm row, between 18-24 in of vac, in MAP A (FUEL) of your SS Box. Say if your at 9.8. try 9.9 and keep increasing in till your idle smooths out. the problem is not the idle speed but how Stable your idle is, that is asuming your idle is set at 650+ rpm. Is your Idle stable? When you drive hard and then slow, shift into Neutral, does the RPM Dive down way below 650rpm? What is your setup again? Show a Pic of your MAP A.
That being said: increasing the idle to say 750 works well, but you must Stablize the Idle with the correct short/long term fuel trim.
let me know if this works for you........
Tim
Old Nov 29, 2006 | 10:32 AM
97supratt's Avatar
97supratt
Do you guys mean the cipher doesn't raise idle for 04.5 only or 04.5+ years? Because it worked on my 06' Z.
Old Nov 29, 2006 | 10:35 AM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
It must be 04.5 only because clearly 05 works too.
Old Nov 29, 2006 | 10:58 AM
THE TECH's Avatar
THE TECH
Yeah, it worked fine on my 03.
Old Dec 5, 2006 | 07:56 PM
kevinapex's Avatar
kevinapex
Ya, won't work only with the 04.5, I got an idle only re-flash to 1100, it is soooo much better, no more stalls at lights, I can now dump the gas from a high rev and the new set 1100 rpm will catch it.
This also smoothed out the vortech big time at idle.
Old Dec 18, 2006 | 03:46 AM
silver nismo's Avatar
silver nismo
Drill a hole there is a huge thread about this....
Old Dec 18, 2006 | 03:49 AM
silver nismo
There u go you can have a look now and read and read untill u r convinced and then just do it heheheh its that easy...
https://my350z.com/forum/showthread....in+the+throtle
Old Dec 18, 2006 | 04:33 PM
RA11325's Avatar
RA11325
I drilled a 1/16th" hole but it wasnt enough, going to go try an 1/8, also thanks for the tip Tim, ill give it a try.
Old Dec 18, 2006 | 06:21 PM
charged's Avatar
charged
Why do you want to going to raise your idle?
Old Dec 18, 2006 | 10:35 PM
silver nismo
it has to be 1/8 to start with and then go bigger and bigger untill u get what u want....1/16 is nothing good luck..
liqalu04
Jan 2, 2022 12:58 PM
350Z_Al
Oct 29, 2020 07:44 PM
NissanZcrazy
Nov 2, 2015 06:03 PM
Darkspy
Sep 7, 2015 09:09 PM
