SS/Vortech wierd problems...Help
Old Nov 12, 2006 | 12:38 PM
RacerZ's Avatar
RacerZ
Default SS/Vortech wierd problems...Help
After installing a Vortech supercharger with an SS box on my Z, it permanetly throws a slip light, a VTC off light, and a service engine soon light. Plus, the sensor in the drivers side window doesn't always work causing the window to roll up and down on its own or not work at all. Other than that, the car works fine, and I've taken it on a roadtrip with no problems...Any ideas? Thanks
Old Nov 12, 2006 | 12:45 PM
ZU L8R's Avatar
ZU L8R
Viper Sellout
Try resetting the ECU
Old Nov 12, 2006 | 01:38 PM
RacerZ's Avatar
RacerZ
Resetting the ECU cleared the service engine soon light but didn't take care of the Slip or VDC off lights. Thanks
Old Nov 12, 2006 | 01:52 PM
teh215's Avatar
teh215
What wheels did you install as well as the tire sizes? SLIP (most likely) = incorrectly sized tires..
Old Nov 12, 2006 | 02:16 PM
RacerZ's Avatar
RacerZ
I have 18" wheels with 275/45-18's in the rear. I had the wheels on for a year before the supercharger installation and had no problem with the VDC and slip lights. Thanks
Old Nov 12, 2006 | 07:28 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
AAM cipher tool should be able to check the ABS computer for error codes, which might be causing the lights to stay lit. Maybe you can find someone with cipher in your area.
I have one, but I live in west LA so unless you want to drive up here, I can't help you personally.
Alternatively, you could check with VRT, I believe they're down near SD
Old Nov 13, 2006 | 03:48 PM
RacerZ's Avatar
RacerZ
Thanks, I'll be heading to VRT next week to get my new injectors installed and a tune. I'll ask if they can help with the VDC and SLIP problems
Old Nov 13, 2006 | 03:50 PM
Mr_pharmD's Avatar
Mr_pharmD
u may have to take it to the dealership to get it reset.
wanderingstuden
Jan 28, 2016 07:03 PM
zachcrosen
Sep 6, 2004 01:12 PM
2003z
Aug 29, 2004 04:59 PM
ares
Jul 26, 2004 06:44 PM
D@ActiveTuning
Mar 29, 2004 06:33 AM
