Map switch #1, but my dashboard reads 0. Correct?
Old Dec 9, 2006 | 09:55 PM
Nic@CiNcity's Avatar
Nic@CiNcity
Default Map switch #1, but my dashboard reads 0. Correct?
So after a million years of not getting to drive the Z, it's FINALY "done". As i'm driving around town making sure i hooked everything up right and have no leaks or anything (Greddy TT install), i decide to give it a little gas. Take it up to 3k and it's starts to get a little boggy. I shut it down and noticed that my dashboard is reading map 0. My map switch is selected to position 1 though (it's the map i want to use). I'm connected to my UTEC via my Tuner Pro, but i doubt that has anything to do with it? On the UTEC it self, i'm on switch 0 as i thought i should be when using the map switch. Correct? Any ideas? I tried switching from 1 back to 0 and back to 1 again, but my dashboard remained the same.
Old Dec 10, 2006 | 06:26 AM
Nic@CiNcity
I can see from the manual that in the Dashboard, Mode = the name of your map and Switch = what number your map switch is on. If this holds true, i'm guessing my map switch might be at fault? Guess i'll pull it, switch the UTEC to 1 and see what happens? Anyone else run into this?
Old Dec 10, 2006 | 06:46 AM
Julian@MRC's Avatar
Julian@MRC
The switch on the UTEC need to be set to the "0" position for the map selector switch to work. RTFM.
Old Dec 10, 2006 | 08:46 AM
Kenk2's Avatar
Kenk2
Professional
I believe that is what he said..
I would pull the map selector switch and dial it in too 1 on the UTEC and see if that works.. Keep us posted..
Old Dec 10, 2006 | 08:34 PM
Nic@CiNcity
I guess it's my map switch. I pulled it, selected 1, and now my laptop reads map 1. I'll have to look it over later on. Now it's on to tuning.
Old Dec 11, 2006 | 05:07 AM
Julian@MRC's Avatar
Julian@MRC
dude, did you not hear us..The UTEC has to be set to MAP position "0" before you plug in a selector switch.Make sure the rotary dial on the back of the UTEC itself is set to "0" first.
Old Dec 11, 2006 | 05:51 AM
Kenk2's Avatar
Kenk2
Professional
Julian..
He had the UTEC set to '0'
He said he pulled the map selector switch and actually switched the UTEC to "1" and his dashboard read '1'.. Seems like the switch is faulty..
Old Dec 11, 2006 | 01:48 PM
Nic@CiNcity
Yes, KenK2 is correct. And yes, my switch is bad. I retried it again today and my dashboard will not change maps.
Old Dec 20, 2006 | 03:43 PM
Hella's Avatar
Hella
the utec siwtch is a piece of crap. Should get more for 75 bucks.
Old Dec 20, 2006 | 03:52 PM
Nic@CiNcity
Mine was broken right behind the switch. Guess i'll buy another one later on
Old Jun 12, 2007 | 07:35 PM
bleunetizen's Avatar
bleunetizen
can anyone post a pic of the switch? it looks like those ordinary switch for scsi id settings and etc.. keen to see how its wired up
Old Jun 13, 2007 | 06:32 AM
KPierson's Avatar
KPierson
I'm pretty sure it has four wires that go in the aux plug of the UTEC. I would assume its a 4 bit binary interface.
2ndchanceZ
Oct 26, 2015 08:03 PM
Depravity
Oct 1, 2015 04:49 PM
