dead battery effect on UTEC
Old Dec 27, 2006 | 03:35 PM
Hella's Avatar
Hella
Question dead battery effect on UTEC
I have the map selector switch. My stock battery died the other day. Bought new battery... problem solved.
Now is my UTEC still on the same map as before? The UTEC itself is on zero....and my switch is on map 3. I was just curious if not having any power will reset the UTEC to a different map. Car feels a little off.....but it might be in my head.
Thanks.
Old Dec 27, 2006 | 04:10 PM
rocks's Avatar
rocks
My friends utec reset its maps the other day when the battery was out for to long. hope you have your map backed up if that happend.
Old Dec 28, 2006 | 01:04 PM
BlackTuner's Avatar
BlackTuner
The UTEC will not loose it's maps if your battery dies. All of your maps are stored on non volatile memory.
Thanks,
Jermaine~
Old Dec 28, 2006 | 03:32 PM
Hella's Avatar
Hella
Thanks,
Jermaine~
thank you jermaine. just what i was hoping to hear.
Old Dec 28, 2006 | 06:37 PM
Audible Mayhem's Avatar
Audible Mayhem
My350z
yeah but here is what happened, your car has reset the ecu, the utec is actually a maf offset on the fuel when you are NA. soo the timing is probably still good but your fuel may be a little off, thats why it feels different, hopefully the computer will learn close to where you were here soon and it will be close to the same...
hey jermaine, please give me a call when you get a second tomorrow, 407 509 3513, thanks
Old Dec 28, 2006 | 10:42 PM
__jb's Avatar
__jb
Z + Rear Seat
That's interesting.
I guess that will always be an issue with a piggyback...
Old Dec 29, 2006 | 04:07 PM
Hella's Avatar
Hella
how long does the battery have to be unplugged to reset the ecu? I was only totally off power for like 5 minutes.
Old Dec 29, 2006 | 04:12 PM
QuadCam's Avatar
QuadCam
Originally Posted by __jb
That's interesting.
depends on what mode you are using the uTEc in.
In MAP based fueling, the inouts in the UTEC are absolute,.....not offsets of the stock ecu.
Old Jan 3, 2007 | 12:02 PM
BlackTuner's Avatar
BlackTuner
As long as it was tuned with open loop fueling turned on, it does not matter if the car was tuned in Maf Pull Down or Speed Density. The end result is that the car does not have control over the fuel.
I'll give you a shout today man!
Thanks,
Jermaine@turboxs.com
Old Jan 3, 2007 | 12:58 PM
IIQuickSilverII's Avatar
IIQuickSilverII
Thanks,
ok so the user is N/A and as you said no problem with resetting ecu, disconnecting/dead battery if the open loop is on... that means playing with the rev limiter n/a (most likely)
all Fi cars should not worry about this then, correct?
Old Jan 3, 2007 | 05:15 PM
Audible Mayhem
My350z
thanks for the call jermaine...
Old Jan 4, 2007 | 06:18 AM
BlackTuner's Avatar
BlackTuner
I wish I could say that but I would be relying on what your tuner has done. Anyone who is familiar with the UTEC will almost always have open loop fueling enabled thus not relying on the factory ecu's fuel table.
All of my Base Maps are Open Loop Fueling enabled.
Old Jan 4, 2007 | 06:21 AM
IIQuickSilverII
thansk for the reply Jermaine =]
lapham3
Oct 7, 2022 03:15 PM
Rev_Night
Nov 7, 2020 06:00 PM
2ndchanceZ
Oct 26, 2015 08:03 PM
Depravity
Oct 1, 2015 04:49 PM
