ECU reprogramming that's not gonna ge me in **** with the dealership
Old Apr 2, 2007 | 01:06 PM
Dildorado's Avatar
Dildorado
Default ECU reprogramming that's not gonna ge me in **** with the dealership
Well as the title says my upcoming mods are:
3.9 FD
Motordyne Plenum spacer
Nismo catback Exhaust
UR HF cats
Popcharger
What I'm wondering is: would a simple reflash do the trick or would I yield better results another way? I would prefer the dealership not know that I'm screwing around with the electronics, you know why.
Any applications that are stealth?
Old Apr 2, 2007 | 02:20 PM
Chebosto's Avatar
Chebosto
dealer isnt going to know you have a reflashed ECU
Old Apr 2, 2007 | 02:22 PM
genegoesfast's Avatar
genegoesfast
I have emanage ultimate and all the mods listed in my signature and the dealer couldnt tell.
Old Apr 2, 2007 | 03:37 PM
tranceformer95's Avatar
tranceformer95
UTEC is supposed to be invisible to scans. I don't have it nor can i confirm, but thats what i've been told.
Old Apr 2, 2007 | 05:04 PM
first350's Avatar
first350
AAM's ECU flash would be really hard to detect...no physical difference.
Old Apr 3, 2007 | 05:29 AM
Dildorado's Avatar
Dildorado
Did you see a good difference with the tune? Also isn't that a piggyback and will look different or is it well hidden?
Old Apr 3, 2007 | 05:42 AM
THE TECH's Avatar
THE TECH
Flash is not detectable like Chebosto said. Also, unless you are getting your car tuned on a dyno, I wouldn't waste money on a flash.
Old Apr 3, 2007 | 11:23 AM
Dildorado's Avatar
Dildorado
I plan on getting it dyno tuned so more than a flash is necessary right?
Old Apr 3, 2007 | 12:43 PM
first350's Avatar
first350
dyno tuned means that someone tunes the car while it's on the dyno...that's usually the most accurate way to do it b/c they can get all the data they need to make changes to the ECU; BUT these changes can be done through either a ECU flash (ie AAM's flash), piggy back ECU (ie UTEC), or full ECU replacement.
What you choose will depend on you; how $ you want to spend, how often you're planning to re-tune it (which also depends on how many more modifications you'll be doing after the tune), and what shops are around you (there's not always someone available to tune what you have...)
in general, here's the differences:
AAM's flash: removes top speed limiter, moves redline point, tunes car. Available for dyno tune (if you live near MD...I know Mike can fly out to tune cars, but I'm not sure if he's able to carry all the flash equipment w/ him). PPL usually do a flash if they're going to have someone else do it and they don't plan on getting a lot of re-tunes done. I had done a dyno of the car before the ECU flash - I sent it with the ECU to MD (I live in Seattle) and AAM Flash my ECU...when I got it back, I re-dynoed it to check AF's and power...the AF was perfect and there was real power gains.
piggy back (UTEC or similar): requires a bit more $$ up front for hardware (UTEC unit, different sensors, controls,...), if you're going to tune it yourself and plan to do it a few times, this might save you $ in the long run...but if you plan to always have someone tune your car, then there's a re-occuring cost of the dyno/tune time.
hope that helps and clarifies the different options you have. If you can give more info, we might be able to help you out in what's best for you.
-Peter
Old Apr 3, 2007 | 12:55 PM
Dildorado's Avatar
Dildorado
Thanks, the shop I'm going to are supposed to be good with e-manage ultimate. Would that be overkill? Next summer I'll probably get more mods as well so i'll have to re-tune once in a while. What I'm most worried about is dealership detection.
Old Apr 3, 2007 | 03:45 PM
first350's Avatar
first350
if you're really worried about the dealership, then you can always remove it before going in...it'd be much more likely for them to say/see something about with your other mods.
Old Apr 6, 2007 | 08:03 AM
Q45tech's Avatar
Q45tech
Dyno tuning is just that tuning [peaking] it so it maximizes dyno numbers.
In the real world especially summer heat you may wish you were less aggressive in wanting the Nth degree.
Why factory leaves 10% on the table to be safe as the miles pile up or to protect against defective gasoline or poor maintenance.
Since dealer only has two sources of income YOU and Nissan Warranty they usually are friendly.
Obadabot
Jun 18, 2023 11:31 PM
BOATS N HOES
Lighting
Oct 13, 2015 09:07 AM
Cashwin
Oct 1, 2015 06:36 AM
hulkout
Tuning
Sep 30, 2015 12:33 PM
