ECU and UTEC
Old Apr 24, 2007 | 03:36 AM
VashZ350's Avatar
VashZ350
Default ECU and UTEC
when I install the UTEC will it reset my ECU ???, which is already reflashed by Tnetics , or will the parameters stay until I do some changes with the laptop?
Old Apr 24, 2007 | 03:47 AM
rcdash's Avatar
rcdash
The UTEC on map 0 will allow signals from the ECU to pass through - so you can always go back to "ECU only" mode. The UTEC will not change the ECU in any way - it merely intercepts signals.
Old Apr 24, 2007 | 04:05 AM
VashZ350's Avatar
VashZ350
great thanks!
Old Apr 24, 2007 | 06:17 AM
MI 35th's Avatar
MI 35th
OGPremierMafia
the UTEC intercepts the signals of the ECU, you will still have the modified rev limit, no speed limiter, and have to alter the fuel and timing curves from what TN has set.
-Don
Old Apr 24, 2007 | 06:34 AM
VashZ350's Avatar
VashZ350
-Don
but if I put the UTEC on 0 .. it will just let the ECU do its work.... right?
or do you mean that if I set it on map 0 I'd still have to modify rev limit etc.... ?
Old Apr 24, 2007 | 10:45 AM
rcdash's Avatar
rcdash
UTEC can modify the rev limit under certain operating modes (that you or your tuner determine is right for you) - otherwise, yes it will let the ECU manage it (e.g. map 0).
Old Apr 24, 2007 | 02:03 PM
VashZ350's Avatar
VashZ350
Okay got it thanks guys
2ndchanceZ
Oct 26, 2015 08:03 PM
hulkout
Tuning
Sep 30, 2015 12:33 PM
