UTEC Front End
Old Apr 24, 2007 | 04:38 PM
KPierson's Avatar
KPierson
Default UTEC Front End
I know there are several different GUIs made to replace the 80s Hyperterminal interface that TurboXS provides with their $1000 engine management system.
I'm getting ready to install a carputer strictly for logging and displaying parameters on my OEM navi screen.
What is everyone using? Right now, I'm using MPS Utec logger - http://mpsav.com/MPSUTECLogger/MPS_U...r_Download.htm
The logging is great, it's very simple to use, but very, very basic. It hasn't been updated in a LONG time, and it doesn't officially support the Z Utec (although it does work). Some of the logging parameters are mislabeled (MAP - Map Load Point, Duty cycle = Injector mS, Maf Hz = Maf V) but it does its job. It also allows logging with either the AEM or Innovate wideband, a huge plus.
Give me some feedback on some other programs out there.
Old Apr 24, 2007 | 05:34 PM
rcdash's Avatar
rcdash
I am just starting out KP, but I went ahead and purchased UTI.
The thread about it is here towards the bottom.
Old Apr 24, 2007 | 06:02 PM
2slo2bfurious's Avatar
2slo2bfurious
UTI looks kicka$$, might have to try that soon.
I use the mps logger prog, but also try autologger sti, its on wrxhackers forums, has pretty much the same options, but it has a graphing function and has analog looking gauges for the dashboard too. I haven't gotten the dyno function to work yet, but otherwise I like it alot.....
Old Apr 25, 2007 | 12:00 PM
Road Warrior's Avatar
Road Warrior
how well does the uti autotune work...does just give recommended settings for a/f and timing?
looks cool
Old Apr 25, 2007 | 12:08 PM
QuadCam's Avatar
QuadCam
looks cool
it only only autotunes fuel. UTI does have a "carputer" mode, though.
The autlogging feature is great with the UTI, and the interface is easier to see while driving.
Old Apr 25, 2007 | 02:00 PM
Road Warrior
does the utec logger give fuel suggestions for target a/f?
Old Apr 25, 2007 | 07:54 PM
QuadCam's Avatar
QuadCam
it does, and it'll give you a new map too. You need to start with something though. You can't just go for a drive, and hope it will make you a map. It is really used for tweaking and making adjustements.
Old Apr 26, 2007 | 10:04 AM
Road Warrior
cool....that is what i need. i already had my car tuned and need to do a little tweaking so this looks like the answer
Old Apr 26, 2007 | 11:10 AM
QuadCam's Avatar
QuadCam
go to www.jeffsoftware.com it is $20.
Obadabot
Jun 18, 2023 11:31 PM
2ndchanceZ
Oct 26, 2015 08:03 PM
