HELP Need a base tune for Utec 550 and sd
Old Jun 10, 2007 | 07:10 PM
plemieux's Avatar
plemieux
Default HELP Need a base tune for Utec 550 and sd
I put on a vortech sc, a fuel return system, wolboro 255, 550 injectors and Speed Density meter for the utec and all is done all i need is a base tune for the utec the ones on Torboxs's web site seem to be currupt. thanks for the help
Yes it is only temporary i am only going to drive it out of my buddys garage over to my house 10 miles vary slow. Then i will trailer it to get it tuned.
Old Jun 10, 2007 | 07:14 PM
iceagetlc's Avatar
iceagetlc
I wasn't aware there were base tunes for that complicated of a setup. You really feel safe running someone else's map? Every car is different.
Old Jun 10, 2007 | 07:16 PM
Jarred@Z1's Avatar
Jarred@Z1
Z1 Motorsports
A base map is ok just to get it to a dyno, but i would defenetly never go boost the car until you know where its at. I had to tune a car similar to that i had to make a map for because i could not find a base. Good luck.
Old Jun 10, 2007 | 07:36 PM
plemieux's Avatar
plemieux
Last edited by plemieux; Jun 10, 2007 at 07:37 PM. Reason: Should of been in my firts question
Old Jun 10, 2007 | 08:58 PM
plemieux's Avatar
plemieux
(Lemieux's friend here) I ended up manually entering the tune. It's running ok, and consistently rich. It'll get us to the tuner.
2ndchanceZ
Oct 26, 2015 08:03 PM
350z82
Oct 1, 2015 06:25 PM
KOF
Tuning
Sep 30, 2015 04:09 AM
