tune with Camshafts
Old Jul 4, 2007 | 08:05 AM
SmokyTyrz's Avatar
SmokyTyrz
How are you measuring airflow into the cylinders?
Old Jul 4, 2007 | 01:03 PM
bleunetizen's Avatar
bleunetizen
not per cylinder.. but the whole air via MAF sensor. higher the voltage, more the flow
Old Jul 4, 2007 | 05:53 PM
dovla's Avatar
dovla
bleunetizen and rocks, what MAF voltages are you guys seeing above 6K rpm? Thanks
Old Jul 4, 2007 | 06:12 PM
rocks's Avatar
rocks
I think it was right at 4.48 volts.
Old Jul 4, 2007 | 06:35 PM
bleunetizen
before cams, the max was 4.7v at redline, in cold dry day. it stayed 4.7v from about 6000rpm upto 6600rpm.
after cams, the max became 4.78v at 6600rpm, in 8deg celcius hotter, wet day. Haven't tested yet but with the rev limit set at 7000~7200, i got a feeling that it will suck more air in.
Old Jul 4, 2007 | 08:19 PM
El Verdugo's Avatar
El Verdugo
Originally Posted by rocks
Nope not an accessport. I sometimes wonder if that thing will even show up.
Nice, well we will just have to wait and hope this system is as good as you say it is.
Old Jul 5, 2007 | 06:21 AM
lightner22's Avatar
lightner22
Originally Posted by 1redZ983
sorry to be a little off topic..but isnt the accessport coming out this summer? they said 3rd quarter.
And before that they said 1st quarter...and before that end of year 2006 etc. By the way it IS 3rd quarter now and they still won't even answer questions about it let alone let anyone know how close to production they are.
Old Jul 8, 2007 | 03:45 PM
bleunetizen
after raising the rev limit to 7200, now i see 4.84v of MAF voltage.
i wonder though, my cams are only allowing more air in from around 6000rpm, compared to stock cams. Does that mean its only making more power from 6000rpm?
Old Jul 9, 2007 | 05:35 AM
bleunetizen
One thing i found interesting while doing timing tune.. is that the entire timing band seems shifted to higher rev range, by 1500~1750rpm.
and it looks like the timing curve is an unside down image of the engine's torque curve.
2ndchanceZ
Oct 26, 2015 08:03 PM
KOF
Tuning
Sep 30, 2015 04:09 AM
