My Dyno Sheet! Questions
Old Jun 20, 2007 | 07:38 PM
Ahsmo's Avatar
Ahsmo
Imakecopies
Default My Dyno Sheet! Questions
My engine mods:
Nismo Exhaust with test pipes
JWT Pop Charger
It was about 95 degrees and humid.
My question is this: Do I need a ecu reflash to correct the little AFR differences? Would a reflash really pull anything more out?
Thanks!
Old Jun 21, 2007 | 06:13 AM
13SECZ's Avatar
13SECZ
tuning will ALWAYS help...that I know..
More hp..maybe 5-10 ...cant see much more...
But it will fix your afr...I believe theres a lil more power in your car....
Good luck..I went with a utec...but you can do that or a flash.
Old Jun 21, 2007 | 08:23 AM
gothchick's Avatar
gothchick
Yeah - Tuning will always help...
Your AFRs aren't terrible in the low 13s. I'm sure you could get more power under the entire curve and up top with some timing/ fuel tuning...
Old Jun 21, 2007 | 08:35 AM
WalkerT's Avatar
WalkerT
Professional
Did you take your filter off for that last run?
Top of the dyno sheet it reads run 3 no filter.
I did that and it sent my AF to 14.9 in spots. Does not look like it changed yours.
Old Jun 21, 2007 | 10:59 AM
Ahsmo's Avatar
Ahsmo
Imakecopies
Yeah I did take it off. I guess that means the pop charger is pretty free flowing? Dunno. I just washed it so...
I am thinking about picking up the STS turbo kit. If that ends up being too costly I'll just get a re-flash. Thanks for checking out my dyno sheets!
Old Jun 22, 2007 | 08:41 AM
Ahsmo's Avatar
Ahsmo
Imakecopies
Welp, I did decide to get a UTEC for tuning but it also comes with a turbo kit...so
issyz
Jul 2, 2017 03:04 PM
Alexreyes
Sep 30, 2015 11:30 PM
Conway_160
Drag
Sep 29, 2015 08:07 AM
