Emanage help simple question
Old Jul 21, 2007 | 06:13 PM
Altimangxe's Avatar
Altimangxe
Question Emanage help simple question
Simple question cause i am a emanage wiring NOOB...
2 things, does anyone have a wiring schematic for the emanage blue?
The "main" harnes is that for ignition or injectors?
I want to be able to mildly tune fuel and a bit of timing.
I ordered the giff cable and i have the support tools cd.
Here is a picture of the harness i have the attached is the RPM Signal 1 adapter.
Yet i have no clue what to do with this....
Old Jul 29, 2007 | 09:24 PM
MDeezy's Avatar
MDeezy
i'll have to dig up the pdf for the eblue harness but the additional harness besides the main, has the added pins for injector/ignition control.
you should be able to get the schematics off greddys web site. Once you have the schematic it will be downhill from there.
not sure if you'll need diods to prevent frying the coils.... something to research before turning the key.
Old Jul 30, 2007 | 09:21 AM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
you can get the installation and user manual for the emanage at
http://www.mohdparts.com/
it looks like the website is down for now, but I'm pretty sure it will be back up in the next couple of days.
I also used a factory service manual to check all the wiring connections. these can be found online, if you look
May 30, 2017 03:28 PM
Dymsi
Sep 29, 2015 11:32 AM
