Does Osiris Work with Built Motor and Turbo?
Hi guys,
Just wandering if any of us have tried using OSIRIS with built motor and turbo? Tried to read through it but havent found a definite answer yet.
Is it still under research?
What do you guys recommend for ECU tuning for built motor and turbo?
Can Osiris be used to rescale fuel injectors and MAF sensors?
Osiris Loader does not support non-stock injectors or MAF sensors. If you need this capability please contact us.
Well basically the built motor and the turbo can go to 550 hp easily. Plus the injectors are RC650CC. So Osiris cannot tune a car that is using larger injectors??
I thought the problem was the MAF?
Thanks for the answer guys. I just want to know the definite answer. Because in the thread regarding Osiris, I saw that some people believe in the near future OSIRIS should be able to tune turbo charge motor.
And Im ready to wait if I can save money with UTEC (while waiting for OSIRIS to be perfect) instead of the permanent switch to FCON. And maybe I also prefer the MAF base tuning. Since I heard from people that there are certain problems with UTEC MAP Tune.
I was at Uprev this weekend and I know they are installing a built motor with a greddy twin turbo kit, and I'm pretty sure they're planning on using Osiris to power it all. Give Jared @ Uprev a call and ask...
Wow! ^^ Thank you for the answer guys its very helpful. I will contact jared. Thanks "mthreat". Anyway if OSIRIS can completely tune a turbo charge Z, it will be great. Hopefully they can do it.
Well I know FCON VPRO is the best! but kind of out of budget right now for $3000 tuned by GTM. So looking for a cheaper and reliable alternative for now. Have anyone used UTEC for built motor and TT? and how much HP they can get?
Originally Posted by Hipknotik
Fcon vpro for best results
Originally Posted by Concept350Z
I thought the problem was the MAF? .
it can be done. its not impossible.
I am the built motor and greddy tt getting installed at UPREV, and yes it will be using the OSIRIS. Should be able to get it in a week or two. Been there getting played with since February. Did have the TN ST on it at first with factory engine, but going all out. UPREV can probably tune/adjust for anything from what i have seen. I had larger injectors with TN, had RC 650 or 750 not sure.
