can utec change rev limiter?
Old Jan 14, 2008 | 06:42 PM
QuadCam's Avatar
QuadCam
Originally Posted by __jb
UpRev's Cipher product can change the idle. It's useful on G's and Z's that are FI, or have cams, or just idle too high or low.
http://uprev.com/products/cipher_NI.html
I think a UTEC can adjust the rev limit on a non-revup G or Z. I don't think the UTEC will change the RevUp's rev limit because it needs to stop the fuel and throttle body. I'm almost positive that UTEC's don't have the capability to manipulate the drive-by-wire throttle assembly.
You can flash the stock ECU. Actually, that's the only thing you would flash... technically, you also flash a stand-alone's EEPROM when you upgrade the firmware, but I don't think this is what the poster above means...
JB is correct! UTEC can only control rev limit on "non-revup" VQ35s; UTEC CANNOT adjust the idle on any of the motors.
Old May 27, 2008 | 07:46 PM
Madelinot's Avatar
Madelinot
Reviving this thread. Another related question: is it possible to retain the factory (ECU) rev limit when I use the open loop fueling and NOT have the UTEC control it? If so, how?
Thanks!
Old May 28, 2008 | 02:46 AM
Jime's Avatar
Jime
Thanks!
Sure, just don't change the rev limit setting.
Old May 30, 2008 | 03:13 AM
Madelinot's Avatar
Madelinot
You mean leave it at 0 in the UTEC ?
Old May 30, 2008 | 03:18 AM
Jime's Avatar
Jime
You can leave the Openloop fueling at 0 which means its off or if you want open loop fueling set the rev limit to stock RPM.
Old May 30, 2008 | 07:36 AM
osinrider04's Avatar
osinrider04
Hey guys I've been looking at buying a chip for a while now and I haven't figured out the best path. All I have is HKS exhaust and CAI. Which route will give the best results: reflash ecu? or buy a chip like unichip or turboxs? Also what are the prices for an ECU reflash? Thanks
2ndchanceZ
Oct 26, 2015 08:03 PM
