emanage removal?
Old Jan 17, 2008 | 06:29 AM
MrKaira's Avatar
MrKaira
Really MrZ31
Default emanage removal?
Hey guys
Sorry, but searching the result for "emanage" and "emanage removal" wasn't that great..
Simple question I hope... can you just remove an emanage, or does the ecu need to be reset by a tuner?
This is for an NA application...
Thanks!
Old Jan 17, 2008 | 07:03 AM
!prjctmax!'s Avatar
!prjctmax!
I would assume that IF you remove your mods along with the E-Manage, then you should be fine...otherwise you will be running like crap and possibly be throwing codes.
dan
Old Jan 17, 2008 | 08:16 AM
PM-Performance's Avatar
PM-Performance
The emanage is only a piggy back. All you do is remove it from the mix and splice together whatever wires might have been placed in the loop rather then just tapped into. IE MAF wires
The car will likely run fine without it. I cannot see a few boltons changing the curves all that much to make it unsafe.
The stock ECU was untouched so nothing needs to be done with that.
Also jumper harness's are nice. You can remove and add back in whenever you want without touching your harness
Old Jan 17, 2008 | 08:45 AM
!prjctmax!'s Avatar
!prjctmax!
AutoSport wiring harness as well
Old Jan 18, 2008 | 05:39 PM
rcdash's Avatar
rcdash
I love "quick disconnects" instead of soldering - easy to remove and put back...
sales@czp
Sep 23, 2019 03:30 PM
3vilbunny
Jul 18, 2017 05:10 PM
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
Depravity
Oct 1, 2015 04:49 PM
Cashwin
Oct 1, 2015 06:36 AM
