tuner pro help
Old Jan 22, 2008 | 01:52 PM
frankie945's Avatar
frankie945
Default tuner pro help
I have a TXS Tuner Pro and need the part # for the Bosch o2 sensor. I ordered one from turbo xs and the clip is wrong. The part # they gave me is 17014. Both clips are 6 pin. The cable I have is 6 pins in a row 17014 is 3 on top of 3.
Any help would be great.
Old Jan 22, 2008 | 08:14 PM
Audible Mayhem's Avatar
Audible Mayhem
My350z
just cut them and make your own clip. match up the color wires to the same.
their might be one odd color that you will need to put together.
the single 6 in a row one is becoming hard to find...
Old Jan 23, 2008 | 03:00 PM
frankie945's Avatar
frankie945
Default tuner pro
I talked to turbo xs today. They said the 6 pin was discontinued 6 months ago. For anyone buying a used tuner pro make sure the cable is for the VW bosch sensor it's the 3 on top of 3 pin, or you will have to spend $99 for a new cable to upgrade it along with the $72 bosch #17014 o2 sensor. Don't try to make it work buy rigging, cutting and so on.
Old Jan 25, 2008 | 12:14 AM
raditz's Avatar
raditz
Do you mind that if I have the tuner kit with the VW wideband I can use that bosch O2 sensor, with the reference 17014? that's good to know in the event that my VW O2 wideband damages
Dark Knight
Wheels Tires
Nov 11, 2015 08:40 PM
KOF
Tuning
Sep 30, 2015 04:09 AM
35reilly
Sep 28, 2015 07:42 AM
