Wideband. Which Bank?
Old Feb 10, 2008 | 10:56 AM
merlin04's Avatar
merlin04
Originally Posted by Abishop
well i guess the Berk HFC's were not engineered right because the wideband port is behind the cat. IDIOTS!
Are you sure the O2 bungs shown in the pic above is not for the rear O2? I am going to guess that it is for the rear O2 not the WB.
Old Feb 10, 2008 | 11:49 AM
mw9's Avatar
mw9
I emailed berk and this is what they said
"The location is much easier to reach than having it up top. It's primarily designed for the casual user who will use them for dyno runs. The more serious car builder will not have any cats. We don't have any on our S2000 or MR2 track cars.
If you are tuning using our provided port, then just keep in mind that it will see a consistent .2-.3 leaner after the cat vs. before. If you are using the ceramics then they will be another .1 leaner."
Old Feb 10, 2008 | 12:22 PM
gothchick's Avatar
gothchick
Originally Posted by rrmedicx
Is this a fact? If so, then I will try to mount the tuning wideband in the drivers side as well. How has this been proven? Just curious.
Sure - here's a Cipher log I ran while we were tuning my Orisis reflash. Check out Bank 2 AFR's compared to Bank 1. Other than that, I dunno, it's pretty much common knowlege for the VQDE...
Old Feb 10, 2008 | 12:26 PM
JAM3Z's Avatar
JAM3Z
Phenom
I know the HKS Knock Amp also functions as an O2 sensor, in addition to its knock-detection functionality, and I know that Philthy has this setup in his G35, which is something I'm curious about.
Old Feb 10, 2008 | 12:42 PM
rrmedicx's Avatar
rrmedicx
Thanks for sharing. Thats useful info. So when Tuning, I will remember to tune using the driver side wideband to avoid leaving it too lean.
Great info. I appreciate the datalog. Thanks gothchick.
Old Feb 10, 2008 | 12:45 PM
gothchick's Avatar
gothchick
No problemo~ Glad to help! Here's a link to some logging Wired 24/7 did that shows bank 2 running leaner than bank 1. He used emanage to log with...
https://my350z.com/forum/showpost.ph...24&postcount=1
Whiskers1996
Tuning
Aug 1, 2020 04:09 PM
Mattg350z
Oct 2, 2015 06:51 AM
abarclay
South East Marketplace
Sep 21, 2015 01:55 PM
Bigsyke
Sep 11, 2015 06:19 PM
