Utec and APS Extreme Fuel System?
Old Feb 9, 2008 | 09:30 AM
Duke52's Avatar
Duke52
Default Utec and APS Extreme Fuel System?
Can I run a Utec with the APS Extreme Fuel system?
The injectors are large(880cc) will i be able to get a decent idle and partial throttle responce?
Old Feb 10, 2008 | 03:41 PM
zerosec's Avatar
zerosec
sure
U need to tune for bigger injectors
Old Feb 10, 2008 | 06:14 PM
captj3's Avatar
captj3
The utec isn't the greatest with very large injectors. It can be used, but your better off going with a f-con,haltech,or pro efi.
Old Feb 12, 2008 | 10:36 AM
Duke52's Avatar
Duke52
I know the Utec is limited, and that you can drive Low Impedance injectors with the Haltech – so eventually I will be going that way. My budget is somewhat limited at the moment though.
I have been searching and came to a thread that stated that APS measures their injectors at 4 bar rather then 3 bar, has anyone else heard this? This makes the 880cc inj rating closer to 660cc – would this be more reasonable with the Utec? Also will the added fuel pressure be a problem as it is not adjustable with this set up?
Thanks again
e
Justin100
Nov 29, 2015 03:58 PM
2ndchanceZ
Oct 26, 2015 08:03 PM
